Glad to have met you on the SAU cruise mate. Good work on the updates, your car looked great and I'll make sure to bring mine next time round it has no issues.
  • Like 1
  • 1 month later...
RBN1 from bitter experience - drive it as much as you can.
took my dirty stinking datsun to Sandown (drive it about 4 times a year) and in the first session developed a misfire (coils/ ignitor).
thing is these things are simply getting old and maintenance starts to add up...
Shizen. When was this?
Speaking of these cars getting old. Found this last night.
Front right driveshaft. Oh well RPM did mention that they needed looking at last time it was in.
easy fix that brother. go down to your local Repco dealer and ask for an outer CV boot for an R32 Skyline (they will match it to a Toyota Part no.) - they cost $13 bucks (by two to make with worth your while) and comes will all the grease and clips (although I believe the clips don't actually fit so retain the orginal ones or just buy them new) and you should be all good to go.
I had to replace mine last month and thats what I did.
  • Like 1
the man loves his genuine tho....
i found it easier to just replace driveshafts man. yea they are more expensive, but you know youve got brand new cvs etc on there.
plus they are much easier to swap than changing a boot.
replace drive-shafts ok................then add GTR tax and your really getting reamed.
the left outer boot is much easier than the right outer boot to undo as you only have six bolts to do undo and yank it out.
peace of le cake
Car is f**ked. I would just replace the entire car. Easier than doing anything on a GTR....... :whistling:
Considering the age of the car i would weigh up replacing the whole shaft. don't want to go back in 6 months.
edit: keep in mind i has no idea on how much that $$$$$
Edited by Anfanee
Although I understand what you are saying Anf.
If the drive shaft is in good condition there is no need to replace it. Just ensure it is promptly cleaned and lubed before whacking it back in (kinda like a dirty hooker really)
10 bucks says he swaps the whole shaft lol
its what? 300 bucks? all new, all genuine....
you know me fellas, im all about cheap and nasty. but OP is not.
Ewwwww but yeah.
LOL.
Spoke to RPM this morning about replacing it. It's due for a service anyway :)
I almost forgot to put up why I was under the car in the first place.
Decided to pop the side skirt off to see why one of them has popped out and get them both replaced with the genuine N1 3 Piece items i'd bought a while ago.
Ended up being a good news, bad news moment.
Good news was, no Rust under the skirts.
Bad news was:
Front left jacking point : No wonder the skirts popped out. The sills collapsed a fair bit from what looks like, careless jacking. Have straightened the seam however, will take it to a panel beater to get it pulled out after next service.
Top view. Skirt can't adhere to the body as the sills bent in, towards the car.
Pesky GTR's.
  • 3 weeks later...
Hmm forgot I had even ordered these until it arrived this morning.
I think I have a problem. Note to self - no more late night scotchs and sitting in front of the computer.
Carbon fibre coated interior pieces.
  • Like 2
Hey rbn1,
Would you mind looking at the part numbers on the front section of the 3 piece side skirts? The small sections that attach to the bottom of the front guards. I need to order some from nissan and haven't had much luck on Google.
Thanks mate and keep the updates coming!
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
