I'm looking for information on cam choices vs turbo size for a car that is aiming to make 350-400 kW to come on boost early in the rev range around 3000 rpm if not sooner ive looked at a fair few dyno graphs but not all have the RPM figures so im only guessing
ive been looking at -5s vs a Precision 6262 or even -7s to try and get the response im chasing
i would also like to know what parts i should be factoring in to try and achieve my goal the motor is going to be a 2.6 running 98
im also looking for advice regarding exhaust manifold and dump pipe sizing eg will going a smaller size improve spool time vs larger piping for more up top
any help would be appreciated as i seem to mill over this in my head on a daily basis at the moment
https://www.sau.com.au/forums/topic/419346-ways-to-improve-response/
  • Replies 74
I think bigger dump is better even if its just a placebo effect, and hook it up with a good boost controller and spike it early, ethanol or meth and alot of ignition timing obviously would help, twin scroll housing etc. My GTX woke up with ethanol and a boost spike, not sure if HPC coating the manifold and housing contributed but a good idea too
Edited by AngryRBGTX
Stroker
High comp
E85
3 big things your setup doesn't seem to have. 350 plus might be a bit of a stretch on -7's without nailing everything.
A big exhaust goes along way. No "ups and downs" in size too.
What are you doing with the car?
Edit: -7's not -9's. Err.
streeter capable of holding its own at track days i dont know enough about stokers to invest but would like to learn if you can point me in the right direction
would the -9s be applicable on a stroked setup? if seen good results from the precison in the reigion of 3000 but that was on e85 comments?
If you wanna hold your own at track days you'll be spending more time and money in suspension, geometry, brakes, rubber, diffs, transfer case etc etc. Over worrying about the outright power. There is a solid 10k in those things, more if you get even more serious.
Prime example here in Vic is everyone said you needed 380rwkw to get a GTR into the 'teens' at Sandown. Then one day it was done solidly with 330rwkw and full weight. It came down to the things mentioned earlier - and a driver with experience and knowledge of his car :)
Put -9s on (so its still responsive around town), and spend time/money in getting the car sorted in the more important areas - especially seat time, as you'll chop times consistently for years In most cases especially as you develop the car. Enjoy milling over that for the next month lol :merli:
Honestly, it's impossible.
My -7s doesn't make full boost at this sort of revs. Nor did the -9s did.
A specific answer.......smaller diameter primaries in the exhaust manifold will obviously give you the best response. There is a mention in one of the other threads very recently about a small bore 6boost manifold (and Kyle's unwillingness to make any/too many of them) that gave better response. You would want to emulate something like that. Most aftermarket manifolds have an emphasis on being big enough to support as much power as anyone could want. They all claim to try to deliver as much response as possible, but I'm sure that if you were willing to put up with a bit more restriction of really high flows you could further enhance the bottom end pick up.
cheers
^ and with good reason, making them response driven from the exhaust side maybe hurts too much in the top end?
You could build the head more specifically for response, but expect once again the top end to hurt (and you wouldn't make that call if you put -5s on).
asking for advice about what configuration will come closest to what im looking for im more will to compromise on the power figure but i want to get as close as possible to the 400 mark
Well on 98 & 2.6ltr, you have little choice as it's a tall ask even for -5s. You'll get to 370rwkw but you aren't going to have the response you want.
-9s will give you 330rwkw pretty much as max and will get as close to your response aim.
Many threads have sorta gone along this way and 10 pages later - it's simply a case of you need to make the choice. This post summed it perfect:
400kw, 2.6lt, full boost by 3k, pick two......
ok so if i accept the fact that im going to have to stroke the motor what would i be looking at in the way of supporting mods so i can get everything in place before i start to build the motor?
what have you guys tried that works i want to do this once and do it right
cheers
^^ this.
I doubt slightly smaller diameter runners would hurt top end on a 400kw e85 build. What sort of power do the standard 6boobs flow?
It's always interesting as the turbine housing is usually always where the restriction is, so promoting flow outta the head larger/smaller runners - would be interesting to see how much response you would actually get.
Well nothing really. Just bolt on turbos and wait until you do the motor.
If it's 3-4 years away then why put wear and tear on motor parts now? :)
Better to do it all at once, so it's fresh, and no weak/worn links in the build.
So seriously, do all the drivetrain stuff I said earlier. Chop the lap times down hard as you can (there is 10k there as i said). Then once you are ready, do the build and then continue development... By which point you'll know a hell of a lot more than you do now, and also be able to drive it much better to actually notice how small changes affect the car. That knowledge doesn't come overnight
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
