Juan from me...I only have 1 a day to give out. I think everyone who has an N/A and wants to make 40+ KW should also give you some free internets as well.
Haha. Thanks dude, I'll spend it wisely.
Will this awesome technique work on my 2L NA Golf?
Disregard matts post.
Bring it down to my shop and we'll see what numbers we can pull.
That's theoretical numbers btw, I don't have a FWD dyno. Bum dyno will have to do.
Bum dyno? How many wasps did your bum run?
Have you thought about a feature on Motive DVD or with MCM to help others unleash the power from their N/A weapons?
Usually about 10kw, if I'm coming onto boost (farting) about 15-17 depending on the ambient temp at the time. If I use some throttle in a bottle by eating Indian I can generate around 28 ahkw
I haven't, but I may consider it. MCM could use some info that is actually useful.
Edited by kawasakirider
Man I don't know if you guys are taking the shiat out of each other or if use are being serious, but fark this kawasakirider dude is taking the piss out of all of use and use are falling for it by the looks of it, dumb and dumber haha lol.
lol..the only one falling for it is you thinking we are all falling for it....Sucker.
or am i the only falling for it thinking that you are the only one falling for it in thinking we are all falling for it
i think I just melted my brain... :wacko:
Anyway this whole thread is f**king stupid and I owe Nik one punch to the face for convincing me to come here and argue with idiots that drag you down to their level and beat you with experience :rant:
drag you down to their level?
youre from frankston, no body gonna be able to drag you further hahahhaa
  • Like 1
Unless there in a vn commo :whistling:
Edited by Captain Natro
No one is punching Nick.
:glare:
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
