Retrofit pretty much complete:
Fixing up broken plastic tabs:
Blacking out the housing:
I'll get some better output shots this weekend when i pickup the car
  • Like 4
 Been driving around with the lights and the light output is amazing i must say.
This is the light output vs new jeep stock xennons. It also is much better than my Evo X Xennons. You can also change the bulbs to Phillips ones which again will be much better:
Jeep Xennon:
R34:
19553505_1750355104978841_983218819_n.jp
  • Like 3
  • 8 months later...
Just an update decided to fix my airbox restriction issue, last time i was on Trent's dyno it was ~10rwkw restriction on the stock airbox.
Bought a 4 inch wide Pod and adaptor.
Got JDM Garage Melbourne to fit it up and do a custom airbox whilst retaining the snorkel and stock look due to VIC Police defects.
29955382_1874006199299512_2026440648_o.j
29993938_1874006232632842_1926842867_o.j
29995944_1874006249299507_1595892933_o.j
30074357_1874006192632846_1626010188_o.j
30069718_1874006205966178_167866352_o.jp
29955419_1874006212632844_1586125424_o.j
29955404_1874006202632845_1904504071_o.j
  • Like 5
Just thought i also would add this in here:
Had the daily Evo X for 2 years.
Mods:
  • BMW M2 long beach blue respray
  • Ce28SL rims
  • TMR SST and engine tune
  • Full exhaust
25991506_10215045001504802_980319403_o_L
  • Like 4
  • 11 months later...
So one night decided to put the car on the roller dynos for fun.
Found out the car was leaning out due to the new airbox. Was also running out of fuel and couldnt lower the boost as the actuator was a 19 or 20psi one and was running at minimum boost.
So now got duel walbro fuel pumps and a Link G4 ecu. Need to get a new BOV as the current one is leaking.
Car still runs on the 5 year old bush bearing Hypergear ATR45 internally wastegaated stock position. E85.
Before the airbox it was ~360rwkw on a roller dyno and ~380rwkw on a hub. (racepace and trents dyno)
So about +60rwkw.
  • Like 1
3 hours ago, ComTruise said:
Just had a look through this thread, amazing stuff! I was wondering is that JDl Kit still available somewhere around here? I would love to get my hands on it.
Not sure sorry i imported from UK and pretty sure they stopped after my one as shipping was too much
Cheers, man. Yeah I have looked around and there is some places that sell it but the price is pretty high and I would have to get it piece by piece (bonnet here, bumper there etc.)
Get some black krinkle HTP on that airbox, it will look less "fabbed".
Well, in my mind anyway.
Hell, my old girl looked stock.....  :)
Yeah that black krinkle looks nice!
Whats the specs on that?
TBH the JDL kit is crap the only thing i got from that thats still on the car was the rear guards.
Every other piece is bits and bobs from other places
UNIGROUP built  it for me years ago, made a lazy 500hp.
It did have its issues, eating OEM manual gearboxes was one of them
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
