  • Replies 57
amarnew in the straya (think how u boy said irt) and got myt nu skylien coz i saw alot sexy man drive this one whe i get hea frm d arrprt then i sad amar get 1 wen i ken get muny and meet tha boys in the sites in cruising and make liftiem conexion with you Aaeron u seem lyk da nice guy that willl do it fur me cany we plz get off 2 nice start and holt hand outta window togetha whil we dreveng?
Is this you OP?
385449_10151253698745868_1702464392_n.jp
Obey caps are pretty cool...I guess...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
