are the grill mounts detachable for the n1 headlamps? or are they moulded to the housing? iv seen some n1 types that have the mounts and some doesnt have it..attachicon.gifimages.jpgattachicon.gifpicture008g.jpg
With mounts = R32 GTR N1 headlights, to secure front grill.
Without mounts = R32 GTS-T headlights.
This is not entirely correct.
No the standard GTS-t's did not have the clips for the grill, although they did have screw holes for an option to fit the brackets (which were metal) for a GTR style grill. You can get these through NISSAN. So any reflector style (N1 style) headlights that have the brackets which are held on by screws and are removable, are NOT genuine N1s.
The genuine N1s have the brackets which are plastic and are molded into the body of the headlight itself. These are NOT removable.
Sorry Damien but that is not accurate.
(OO)SKYLINE(OO) is right.
Genuine N1's do not come with plastic brackets molded into the headlight. Standard R32 projector type headlights do.
If you were to source N1 (Zenki) Headlights from Nissan they come with metal brackets that are bolted each N1 headlight.
GTS'ts have N1 type headlights without brackets and can sometimes fool people that they are genuine N1 headlights.
I have both sets (with N1 recently purchased) be more than happy to post up pics for comparison.
Edited by Ants
Hey Ant,
I spoke to Kudos (SAU trader) about 6 months ago about this same thing as i was after genuine Zenki N1s, and he supplies them direct from NISSAN Japan, and he assured me the brackets were molded plastic (like the GTR projectors) and are part of the body and not removable. This is what distinguishes the difference between the N1 and the GTS items.
I did a fair bit of research into this as i was searching for a set myself, and i found a lot of conflicting information and could not get a straight answer, so i spoke to a specialist who deals in new original Nissan parts.
Ill ask someone on here who i know purchased a set through them so i can get a straight answer and ill let you guys know.
i prefer my projectors ;)
i wonder why they never moulded the braket on?
Well I have both. So change it when I want :yes:
No idea why N1's were not molded on - maybe it was in case they got damaged in racing it was easier to fix up :closedeyes:
hmmmm, bolts=metal, they should be moulded for light weight :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
