when i purchased my gtr, the owners brother(owner wasnt there, everything was legit, so all good), handed my os giken twin plate(needed rebuild).
looked underneth, had tien coilovers.
trust 4inch cooler.
tuned y pipe, 3inch cat and cat back.
those were the parts i didnt know of.
did you check and see how good the ah 'mines ecu' under the back seat was, or did you just throw it out?
Tossed it ,it was not in very good condition,i think it had been there a while.
Edited by I gotta R34gtr v-spec
I bought my 34 a long time ago.. About 2 years after i bought it i went to install red bulbs behind my dash. I took the dash apart then went reaching in behind there and found some wires that seemed a bit "out of place".. So i looked up under there and followed the wires back and found a Greddy full auto turbo timer sitting in there!? hidden amongst all the other wires. All i had to do was turn it back on and mount it and boom. Free turbo timer. :D Also found a Japanese jdm game token coin like thing under my seat..
Found a 1979 20cent piece behind the roof vinyl interior of my 1981 Stanza. So I can only assume the coin was lost there while the car was on the assembly line. Still have the coin somewhere....
Jeff
  • 2 months later...
Found yellow jackets tucked down the left side of my r32's boot still in there packets! (Hopefully will fit my rb20) :)
Was looking at buying rear hicas lock bar.. Had a look underneath and already had one :)
Nismo front strut bar with Nismo stamped into it (hopefully genuine.. Not sure if those are even rare..
And last but not least about $18 worth of shrappaz!
In my 33 i Found split fires, dodgy wiring in the tail lights, really old jdm gaff tape in the doors, wierd wires all through the car, a USB with the guys birth certificate license and all his tickets, jdm coins, aus coins $14 worth, Japanese rego sticker
And the classic dried up maccas chip
4 children's nursery rhyme CDs behind the dash, played that shit all day!
Shell battery from Japan? You can't buy them here.
Shell service stickers all over and in the car from Japan.
On my gf car I found a threaded head with the spark plug sitting on top and some more threaded bolts on the thermostat housing. It was a fluke it even ran.
found tanabe GF210 on my stock springs heh i knew them orange springs were weird! also found the lock nut key from previous owner's set of nuts, which he had the tyre guys smash off, thus running only 4 nuts (until i bought a new set of nuts). what a nub. it was in the compartment which had the spare tyre jack in it, i noticed something rolling around inside.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
