Ok I am on my 3rd afm in 6 months..
New one arrived in post today plug it in and it idles for a bit then stalls. Give it gas it cuts out.
I tried putting the 2 blown ones in and the car goes into limp with them in.
I doubt this part could of died with 0 run time.
I'm in ramsgate sydney, does anyone have an m35 I can bring this new afm too, so that I can test to see if the part is or isn't faulty?
Tried the fault code thing I can't get it to work. Or my cel is blown.
https://www.sau.com.au/forums/topic/420808-m35-afm-troubles/
Did you do the ECU reset between trying the AFMs?
I can read your codes / erase them. I can also Log the AFM volts to see if it spikes or does anything abnormal. Only one other car I have seen did this, and it has been running fine for a while now using one AFM after going through 3 or 4 in quick time.
Simple things to check would be the connection, and a visual inspection of the wiring loom, and ECU plug. Make sure your AFM is sealed neat on the back of the airbox, and the filter is placed in so crap isn't getting by it.
I'l try it in mine.....Alex is 1 minute from my house too so you could kill 2 birds with one stone.
Will have to be quick though because both of us are off to PI next wednesday for a week!
IMPREZA WRX and STI 1998-2000
FORESTER GT 1998-2000
also NISSAN
PATROL 3.0 GU, GU2, GU3 Turbo Diesel ZD30DDTI 2000-2004
Pulsar 1.6 2000-2003
Pulsar 1.8 2001-2004
Maxima A33 2001 on
Part Number:
22680-AD21A
22680-AD200
22680-AD201
22680-2W200
22680-4M500
22680-4M501
22680-6N200
22680-6N201
22680-AA290
22680-AA301
22794-AA000
22794-AA010
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
