im yet to put mine in too just need to get my fuel rail. Which fuel rail did you use to fit it under the plenum.
Anychance you could also tell me if the R34Neo injectors you pulled out were 11mm or 14mm. Seems to be two answers on the threads im reading.
Edited by B-rice
Just used the standard fuel rail and 4mm spacer man. It still clears the plenum easy as, no worries there. Ah to be honest i didn't even measure the size difference between the old ones and the new ones. I just sprayed lanolin on them and they went into the fuel rail fine and didn't move around at all when i put the retaining clips in. With my luck i wouldn't be surprised if i bought the wrong ones haha, anything i do seems to be one step forward and two steps back!
I've got my stock injectors sitting in a box at home, ill measure them for you tomorrow. Pretty sure they are 14mm though.
Sweet, cheers dude.
Also, new turbo finally arrived! It is much bigger than i thought it was going to be hahaha. It is going on tonight and is the last thing i have to get sorted before the car goes down to trent this weekend for tuning! Fingers crossed it bolts up all sweet and i don't have anything bite me in the ass >_<
Edited by iruvyouskyrine
Any idea what size studs I need? And how do I get the olds ones out?
Trying to make it fit by clocking the turbo but don't think it will work.
From memory the factory ones are 42mm, so it depends what size spacer you have. I think Stao uses a 15mm spacer, so you will need to get studs at least 15mm longer. I believe I went with 67mm studs.
Standard studs are 39mm, parts that protrude from the manifold is only 24mm, turbo housing is 10mm, spacer is 16mm.
So standard studs are 2mm Fromm even being flush with new turbo.
Will try and get it all sorted tomorrow, hopefully have enough time to get it sorted before this weekend >_<
This is what i would be after yeah? Hopefully can source some locally if not then i'm pretty much farked before this weekend haha.
http://www.sonicperformance.com.au/95015/Stud-_and_-Nut-Kit-GT30_or_GT35_or_GT42_or_GT45-M10x1.5-X-4/pd.php
Yep, they are what I used. Be warned, mine warped severely after about 2000kms. I had to cut two of them to get them off.
But MTQ were very surprised and said it shouldn't happen, and because I couldn't find any inconel studs I just used the same ones again. They seem to still be ok.
Got the turbo on finally after fighting with oil and water lines. Found it interesting that the turbo doesn't have a little nipple or similar to run to the wastegate? Just used a spare nipple on my plenum and run it to that.
Run the wastegate as close to the turbo outlet as you can. Stao really should put a nipple on the turbo. But you want the wastegate plumbed into a source as close to the turbo as possible, because of you get a leak somewhere and the boost pressure is lower at the plenum then you could be working the ass off the turbo, superheating the intake charge. If that means getting a nipple put onto the hot side cooler piping then do that.
Would probably be ok for the tune. You should really check for leaks before it goes on the dyno anyway, but hopefully it's ok. But if Trent can't do it, I wouldn't worry too much about it. Just do it at some point.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
