  • 3 weeks later...
Nah I just want a standard one with the front chopped or a legit GTR one. Only running this one as this happened unfortunately.
Edit. Forums being gay can't upload pics. Bonnet made love with windscreen and roof.
I remember when your 6th piston didnt like the world and overheated.
quick question, are you still running the gktech clutch Fan?
Because ive heard nothing but problems with that fan on Neo engines, Stock is better.
stock fan with a decent radiator works tits, those GK Tech fans are hideous - pointless mod, I removed two of them off 2x S15s that were overheating on the track.
Yep still using GKtech fan. Temps are fine but haven't abused it on a really hot day yet. I need to find a R32 radiator shroud first then a stock clutch fan that actually works which will be difficult. Once I have all the parts I will do it then :)
Have Gktech fan on S2 RB25, stock shroud, temps are great, done many laps with no problems. Only complaint is fan hub is always locked when running, but don't know if that's because of the fan or not.
Bought a shroud, should be here mid week. Doing a drift day at wakefield next Monday so I'm super keen for that.
Bought some tyres to get out on rims, as did my friends. Lucky we have access to a tyre changer!
  • Like 1
  • 3 weeks later...
Cam seal has been leaking since the car has been running. Decided to fix it today. Pulled all the shit off and found scoring in the exhaust cam, and also found some black shit on it as well, looks like the seal may have been unlubricated and is slightly melted onto the cam. Sweet.
So undecided what to do at the moment. Will grease them up and has been suggested to put the seal back in but not in the same position as before. IE 1mm further in or out.
Also had planned to do a wakefield drift day 2 weekends ago, but the night before it the MAP sensor on my ECU dishonoured it's family and killed itself for some reason. So took it to Jez and he swapped it over for me (top bloke).
Fun times.
post-84937-1429443694734_thumb.jpgpost-84937-14294437116086_thumb.jpgpost-84937-14294437318415_thumb.jpgpost-84937-14294437609681_thumb.jpgpost-84937-14294438267172_thumb.jpg
I'd like to know how you get the timing right, is it just a matter of getting the right belt , install tensioner on block and just line the marks up or is there a more precise way to get it spot on?
Can you get adjustable wheels for both intake and exhaust side then? Just trying to visualise how the crank and two cams can be in the exact spot without having everything adjustable..
Can you use the tensioner for adjusting it too? hmm
Edited by AngryRB
Was just after a quick answer, i know what a tensioner is for, thanks for your wise answer, its an hour drive each way with an engine on the ute for me so id rather learn on here... from what ive read so far, the timing on an RB30DET can be tricky compared to a stock RB25, ill just line the marks up and let my tuner check and adjust it before its tuned then.. ;)
Edited by AngryRB
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
