This gets talked about often so obviously people are interested to know if the complete RB25 inlet manifolds can be substituted from R33 25DET to R34 Neo Turbo and vice versa .
There are good reasons to attempt this ie R33 engine in R34 or the other way around . Obviously the injectors and throttlebodies/TPSs are different but if the whole assembly can be exchanged in some circumstances it could make life easier .
Anyway its been said that the Neo RB25DET has slightly smaller inlet ports and runners at the manifold flange . Most people think the Neos make better power than the R33s do even in modified form maybe the ports and manifold sizes were changed for good reasons . The way to check if the manifolds are interchangeable is to compare inlet manifold gaskets I suppose because that confirms stud holes water jackets and ports line up - or not .
I'm not sure of the wiring situation as in if the injector loom plugs are the same , I hear that the coil loom plugs are the same .
I believe the throttlebody mount on the plenums are the same so you can go either way .
The things I'm not sure about is air plumbing and the idle and cold start valves , wiring would be different here .
Anyway first things first will they bolt up to their opposite numbers head ?
A .
I have wondered this my self and found very little solid information. I have a R33 Greddy plenum here and have some inlet and exhaust manifold gaskets on order from Nissan to suit a NEO, so as long as the Greddy manifolds are matched to the R33 head correcly we should get an answer. I'll post up results once the gaskets arrive.
manifolds swap over, the electrics seem to work much the same, have run 25neo de with all its elecs off an r32 25de ecu(changing cas & coil wiring, & a few plugs), ran mint-not saying this is the preferable way but shows elecs can work together, with both motors in good condition power result for same mods should be very similar, i've got a neo to replace a s1 when it dies which i'll use the same setup (300+kw) for back to back
Inlet manifold gaskets are the same part number 14035-75T01-.
Well that would have to solve the question as to whether the ports will match up. Didn't even think to check that way, nice one.
  • 2 years later...
I was comparing R33 S2 and R34 neo today, is it normal for the Neo intake runners to be smaller diameter than the ports in the Neo head???, so therefore giving it a step/ slight mismatch?
The one with the blue on it is the R33 intake, looks like the area around the injector is different too, the R33 one is wider and more open..
Edited by AngryRB
The Neo intake manifold is narrower around the top / injector area, however on the head it is the full width of the gasket.
  • 2 years later...
I managed to get my hands on an almost bare and a complete Neo turbo inlet manifold to play with because I think its a better setup . I don't have an R33 to compare atm but I know someone that does . I want to measure the difference at the ports and where the plenum mounts on the lower section .
As we know the TBs and bolts interchange , one thing is the 33s TB gasket is steel where the 34s is paper . The 33 has a rubber gasket between the upper and lower section where the R34s is steel shim .
Something I need to find out is the ID of the coolant hose rising up from that fitting on the block behind the water pump , it connects to the Neos front bleeder section .
At a glance I think the R33 is ~ 8mm where the Neo could be 10mm . Its that hose which heads down next to the front rubber fuel hoses .
A .
The r33 throttle body has to be modified as it is different as there a small vacuum channel/hole on the r33 that a neo throttle does not have.  The area where the injector sits is larger in the r33.
Edited by AngryRB
Ah , I was going to ask the differences but thought I'd better search first . I'll have a look at my R33 soon to see what that vacuum hose goes to , I suspect the charcoal canister .
Yes I knew about the top of the manifold ports being different , the head ports are supposed to be the same in this area R33/R34 .
Cheers A .
From memory when you split the manifold the location of the runners are in a different positions to the 33 manifold.  Thats why the plazmaman manifoldd are different from  33 non neo to 34 neo.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
