  • 4 weeks later...
So, car is getting dropped off to Jez this coming Saturday. Needless to say I'm pretty keen.
Brief run down, Xspurt 1000cc, Walbro fuel pump, Z32 AFM. I was originally planning to fit a Hypergear SS2, but decided the slight power increase wasn't worth the coin. Plus I really enjoy the responsiveness of the current high flow that is fitted. Hypergear rates them to ~260rwkw which should still be nice and fun.
After discussions I have also opted to change from the PowerFC to a Nistune. There is something else worth mentioning here, but I'll wait until it's done, unless someone can guess :ninja:
A friend at the hill climbs also finally posted up the video of my "tyre warmup procedure" haha.
Haha, nice :laugh: .
At the Hillclimb I did, you were only permitted to 'clean the tyres', and you got kicked off for 'doing a burnout' :closedeyes: .
Whats the difference? :rolleyes:
^^ This. Lol.
That video was on my last run but I had done pretty much the same the last run. My 'warmups' gradually got bigger each time haha.
So the car has been with Jez since last Saturday, and I am picking it up this coming Saturday.
Battery has been relocated to the boot.
New intake piping has been made up.
Injectors, fuel pump (direct feed wired up), and Z32 AFM have all been installed.
Nistune board is installed in the stock ECU and the car is on the dyno today with a fresh set of plugs and a new fuel filter :D
Edited by timmy_89
  • Like 1
Ok guys car came off the dyno yesterday afternoon.
I'm pretty happy with the results. Peak power was 238.5rwkw at 18.6psi dropping to 16.2psi. The turbo was literally running out of puff and couldn't push anymore power, which is evident by the fact it made 237.4rwkw at 16psi haha. The car also made 203.8rwkw at 10psi, which is the same power it was making when the original owner tuned the car with the stock turbo at 15psi lol. The car also made 610nm of torque which I was surprised about and pretty damn happy with.
Dyno chart showing power for different boost levels.
Dyno chart showing peak power and torque.
Cheers guys.
Good results but I thought Stao said his new highflows made way more power than that.
Is this an older version or something Timmy?
I have owned the the car for roughly 2 years and the high flow was done 6 months prior to me purchasing the car.
When I messaged Stao he suggested it would be good for up to 260rwkw as we are under the assumption that it was the original OP6 turbo that was high flowed and refitted, I have nothing to confirm this though unfortunately. Jez said he recently tuned an OP6 high flow in a car running United 100 octane to 270rwkw so they are obviously capable. Being in the dark with the turbo it's hard to know. I was hoping to hit the 250kw mark, but it is still a responsive 240kw and has more torque than I was expecting, which will be more important for me really with entering NSW Hill Climb Champs next year :)
So, picked up the car on Saturday, pretty happy with how it performs, nice and responsive, sounds much nicer and has a bit of a rough sounding idle which is cool. Also, most high rpm gear shifts pop and sometimes shoot flames lol.
Anyway, after the 9 hour round trip to get my car, the inevitable happened once I got home.
For the first time ever, I was pulled over for a "random" vehicle inspection :(
The cops were from Armidale, being all the way out here because it was the Bathurst race weekend.
Luckily I received no fines, apparently because of my good attitude, but the car was defected for unenclosed pod, too low, and wheels protruding from the guards. Anyway, now I have 14 days (minus 2) to get the car to pass a full inspection/blueslip. Best/worst birthday lol. Happy times :'(
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
