It seems Garrett GT30xxRs are popular upgrades on RB25s but they don't just fall in so I'd like to know whats the best bits to make it happen . Basically you need a dump pipe and an inlet pipe and a spacer plate to get the compressor housing off the exhaust manifold . Then you'll need longer mounting studs and plumb oil and coolant in/out .
Someone here mentioned that Liverpool Exhausts make a nice one piece dump and front pipe so that would be handy . It looks like like the easiest suction side would be a 90 degree 4" to 3" silicon or rubber bend and some sort of steel/aluminium/stainless tube section to connect the plumbing and AFM . I say AFM because some people like have something that looks like its doing something and connects to the std airbox .
I don't know how inconspicious you can make a GT30R but the more the better IMO .
So , can we have some examples of what/whos bits people have used to fit these turbos to RB25s .
Cheers A .
A bright blue silicone bend won't be conspicuous, lol, but seriously if you run a silicone 90 off the front it will suck in on boost. You need a stainless or alloy hardpipe intake, that much has never changed.
Don't like blue as in silicon or uniforms . It would have been black or preferably flat black .
I did find in Mick o's thread a pic of his dump/front pipe .
http://www.skylinesaustralia.com/forums/topic/375232-garrett-gtx3071r/page-9
I like bell mouthed ones myself .
Does anyone have pics of an install that retains the std airbox and possibly the MAF ?
Cheers A .
black silicon joiners for intake hardpipe , powercoat black 3 inch metal intake and comp cover of turbo , and remake a turbo heatsheild from the ACL shit
you can completly hide the big comp cover with the ACl stuff ... easy..will look stock to anyone except skyline heads, you can even
hide a 38mm gate of exhaust housing easy with that stuff, Im doing it atm, just waiting for stuff to come back from powdercoaters
then i have a made up airbox, that hides the Boost control solenoid, oil catch can and radiator overflow
cheers
darren
Edited by jet_r31
That's on a stock turbo though isn't it Scott? DP is specifically wondering about whether that could be done with a GT30 on a spacer plate off the stock manifold. Obviously it's just a tweak to the design, seeing as shit won't move far, but it appears he needs reassurance.
Attached are photos of my intake pipe, linking my Z32 to my Hypergear with a breather in between.
The pipe was made by Mick_O, who is an absolute perfectionist when it comes to this. He's in the west and I believe he will be happy to fab one for a fee for anyone interested.
The welds were done to a colouring and finish that i requested. He noted and showed me that he can also make the pipe to have no marks or burn colour. The pipes are also made from medical/food grade stainless bits, all butt welded except on the 20mm bung (no filler wire).
You can obviously prep that and paint is fluro pink if you like. Matte black wouldn't be hard either.
Yep, works on any turbo in the stock location (low mount). 80mm alloy should be good for well over 350wkw.
I use a 4" - 3" reducer off the turbo, 3" 90º stainless bend, 45º silicon and 3" stainless 45º bend to the afm. I use a custom airbox as I experienced lots of stalling when backing off the throttle with just the 90º bend. Then the usual spacer, dump/front, solid oil drain and braided oil feed. Seems to work.
Well I basically wants a "suction" pipe made to line up with the GT3076Rs (same dimensionally as your GTX3071R) in stealth black . Aluminium would be nice because it won't rust internally .
I also need a dump/front to suit the GT30 0.82 AR IW turbine housing , I have a large body 3" Catco 8007 in the std location and it fitted the std front pipe .
I was speaking to the feller I wanted to fit this turbo today but he's a one man band booked out for weeks servicing daily drivers .
I reckon with the main bits made changing over shouldn't take that long . I intend to reuse the GTRSs oil and water lines because they fit the same .
Mick do you still have your Z32 and airbox ? If so would you consider making me the inlet section using yours as a template ?
Couple of things I was wondering about . I always thought thermal wrapping stainless was no issue and my old dead Subies fabbed stainless header was like this . I was told today that wrapping staino would make it harden and crack though thats not what I've found in the past . It would be good to keep the heat out of the bay and in the gas with the dump/front pipe .
Also whats the go with longer manifold studs , does anyone make anything OE std ?
Cheers A .
I wrap all my stainless dumps, I have never had any come back.
I think they are talking about thin stainless exhaust manifolds, as I have seen them glow white hot before. Not something you would want to heat wrap.
Does your suction pipe require bov/breather fittings also?
Cheers A .
Sorry bout the slow reply disco but i have sold my car and all the parts too so need another 33 to work on mate :unsure:
I dont do much alloy work tbh stainless is what i work with and it wont rust internally either btw :whistling:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
