Nice mate. Wow how cheap is it to run your car at that track! Wonder why SAU havent organised something there. Great build mate will be interesting to see how long it takes to um streatch the reliability after your history with the RB's lol. Will definately have to take my 32 down to that track for shakedown once shes finished.
yea its a small track and a bit of fun, its 100 bux for they day.
i rent the joint out once a year for my birthday for some fun
8th june if your intretsed cost will be $150
That car is far too clean and shiny to be a fatz mobile.
PS welcome to the highly exclusive white series 3 owners club.
belive it or not i have washed it... i have changed
will be getting a polish this week as it has some spots on the paint fron parking under a tree that didnt wash off afer a quick scrub
^^^ :D
in other news the car now has a decent alarm and we have booked it in for a wakefield track day on anzac day!
Have a look under the rear parcel shelf, where the Hicas ECU etc is.
Tomei rack is an electric unit with a couple of brass spacers that go between the tie rods and the rack. I installed it for Grant.
SAU NSW has done a day there. They lost money because people didn't want to turn up.
Fatz: Where'd you mount the fire extinguisher in this one? :P
decided to sell the front brembos as they are camp
this weekends plan is new plugs
swap out the front brakes with stoptek's ds 3000 pads
remove dust shields
new ds 3000 for the rear
braided lines all round
put a temporary catch can in
cam gears to zero
new exhaust( with cat)
new cam covers with mines baffels
check earths to the fuel pump
fuel fliter
air filter
gearbag oil
polish
i recon ill get 2 out of the 10 things done!
Cool cool. Yah mate put me down for the June birthday bash. Do you know a place that has cheap car trailer rentals? Kenards do $150 for 24 hours but $350 deposit :( This means i must now definately have the 32 done lol.
Cash cash guess ill have to come up and pick the rear screen up and pay you an extra $150 ;)
Yah if i could afford to buy my own trailer i would, but just cant do it yet lol. I got a mate with one think i might steel it
for that day :)
Changed the plugs on this thing today
Fake nismo catch tank added for short term love
Can't find my mines baffles in my shed either
Also ordered a surge tank, same as pigsarses one
And I think ill get it tuned on e85 as its a track bitch
The spots on the shit heap won't come off with a quick polish which shits me... Will have to cut and polish.
Trying to swap the twin exhaust. If no luck by Thursday it will be getting cats added for rego
f**k me
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
