  • 3 months later...
Dusting of the cob webs of this bucket of shit.....
To enter in the gtr festival at ec drag strip
Na just joking
Going to Bathurst to slap it into a wall in a true gtr death
New oil, new 50 dollar rubber on all 4 corners
To prove I am serious I have booked it in for an Alignment
Chance of death high
  • Like 4
Minor update
Just some basic maintenance
Noticed when driving to get a coffee there was a wobble when tuning left
Glad I had a look see
All the camber bolts were loose... I mean farken loose
Also the front right tyre kept on going flat. on closer inspecting must have been a dud
Lucky I found that, rubber was like this and had a
Minor wobble at ec last track day through turn one
post-219-0-84709000-1461585089_thumb.jpgpost-219-0-14281500-1461585138_thumb.jpgpost-219-0-22016200-1461585173_thumb.jpg
Started dicking around with front splitter
Also nutting out a better tow hook
  • 3 weeks later...
Great to catch up big fella. Sorry I had to bail early but I had an awesome day sanding a floor to look forward to on Sunday. With a splitter like that you should have scored the "best presented" trophy for sure. Well pedalled on Saturday mate. Embarrassed some serious cars.
  • Like 2
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
