  • 3 months later...
Dusting of the cob webs of this bucket of shit.....
To enter in the gtr festival at ec drag strip
Na just joking
Going to Bathurst to slap it into a wall in a true gtr death
New oil, new 50 dollar rubber on all 4 corners
To prove I am serious I have booked it in for an Alignment
Chance of death high
  • Like 4
Minor update
Just some basic maintenance
Noticed when driving to get a coffee there was a wobble when tuning left
Glad I had a look see
All the camber bolts were loose... I mean farken loose
Also the front right tyre kept on going flat. on closer inspecting must have been a dud
Lucky I found that, rubber was like this and had a
Minor wobble at ec last track day through turn one
post-219-0-84709000-1461585089_thumb.jpgpost-219-0-14281500-1461585138_thumb.jpgpost-219-0-22016200-1461585173_thumb.jpg
Started dicking around with front splitter
Also nutting out a better tow hook
  • 3 weeks later...
Great to catch up big fella. Sorry I had to bail early but I had an awesome day sanding a floor to look forward to on Sunday. With a splitter like that you should have scored the "best presented" trophy for sure. Well pedalled on Saturday mate. Embarrassed some serious cars.
  • Like 2
