No im dan im a writer for Estblshd and I want to talk to them about doing a feature on their GTR if they are interested of course.
He'll be more than interested lol!
Ill organize for him to contact you, if you wanted to pm me a contact number it would be easier
  • Like 1
orly? hmm i've never won anything.
first time, i was at crown gambling, then at sns, nothing, then yesterday i went home early.
maybe i should be selling those numberplates.
Your car related life has taken a beating since acquiring...I advise against keeping them.
You did win somethig.
You won a raffle prize so PM John, you should be getting a SAu Vic shirt and hat
can someone please pm me with regard to winning the outright prize - which was for some motul oil iirc :D
just need to know if it was left at RTR or not - im hoping its the right rating for my evo x
Was left at RTR for you I think Oscar was under the impression you were going there this week
Also the owner of the R32 with like 7kws less than the R35 who is that?
the r32 was very close to that tune + exhaust r35 at 320
amazing numbers for an r32, and i could only imagine how brutal that power delivery would be on the road
+1 for full results
didn't think i was going to beat that big turbo white r35 with my stock turbos and 21s.....kudos to Martin Donnon (Willall Racing) the r35 whisperer
haha sorry a-a-ron, was busy drooling over cars and every time i saw you you seemed busy with all your mc'ing!
313kW, damn, that's near what the red 35 pulled before it conked out isn't it? good shiet.
*shuks* haha thanks guys yeah pretty happy with the results after hearing the dyno is a greedy one
any one got any photos of mine? ive seen 1 from GSS mint one too
thanks to Aaron and all that organized it all and Halle and his Mrs for cooking the bbq and RTR for hoisting ,was an awesome day
  • Like 1
I thought Richo took them to distribute later? Not sure, best to check with him.
Congratulations on the win Sam! :)
Great pics Asian boy!
So we have a winner that was chosen at random for the DRIVER DYNAMICS TRACK DAY!!
The winner is
RAVEWAR
Derrick Teo!
We will be sending this one out to your address
Congratulations !!
Did I just won something???
Sorry, I left for work after I signed up the membership and got a couple of shirts...
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
