It gives me great pleasure to announce that we are the New World Record holder for Fastest H-pattern Street Tyred GTR on the planet.
After coming so close to the record last year at the 2012 Brisbane Jamboree with a 8.97 sec pass, we were in good contention to take the record, but in drag racing things fail and 3rd Gear decided to throw in the towel after having a promising half track time. This only left us 0.02sec off Theo's time and making us ever so hungry to achieve that goal.
So we decided to head to Benaraby Dragway for the weekend for Round 3 of the CQDRA Championship to give the GTR a run. This is its first run since blowing the gearbox up at last years Jamboree in Sept. Now I really wanna give the guys and gals and Benaraby Raceway a huge wrap for the awesome event they held and the support they gave our car was unbelievable. The track condition was perfect, best I have seen if not better than Willowbank. They are doing a terrific job out there spending a lot a dollars to get that place up to spec. Great Job keep up the good work. ;)
Before I go into too much detail. I got to give our Main Man Mr Mark Jacobsen from Godzilla Motorsport a huge thank you, for all he has done for us, his support and knowledge has been unbelievable without his over the phone late night support that night this would never have been possible without him. Proud to part of the Godzilla Motorsport Team. Secondly another huge thank you to Dave Sheehy at CPV Tuning, for his continual help for the team, his valuable knowledge and input helped us immensely.
Ok to the runs, we not only broke Theo Woollett's previous World record 8.95sec @ 159 Mph which has stood for over 6yrs put we managed to back I up 4 times in a row, completely smashing it out of the ball park.
1st pass - 8.91 sec @ 152Mph with a 1.33 sec 60ft
2nd pass - 8.65 sec @ 150Mph with a 1.23 sec 60ft
3rd pass - 8.59 sec @ 152Mph with a 1.27 sec 60ft
4th pass - 8.52 sec @ 162mph with a 1.30 sec 60ft
With that said and done we are now gonna chase down the next record which is (correct me if i'm wrong) the CV Performance R32 GTR which currently hold the record at 8.47 sec. For the fastest radial GTR in the world with and gearbox setup. That puts us at 0.05sec behind, can we do it, hell yeah we can gonna be an exciting year stay tuned for updates.
Here is the pic of the golden ticket
923221_10151549364763485_1046025106_n.jp
And a couple of Vids:
Cheers for the support everyone, yeah would be great to be the World No.1 with a H-Pattern Box. Would be an amazing feat of engineering on our part, a lot of custom secrets in this gearbox, we must be doing something right.
Here's my favourite pic with the flames out the sides.
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 2 months later...
http://www.speedhunters.com/2013/09/aussie-rules-straight-shooting-at-j23/#chapter-a-festival-of-fast
On the subject of records, another machine that set one at J23 was Matt Earl’s Nissan Skyline GT-R. With a 2.7-litre JUN-based engine built and tuned by Godzilla Motorsport, factory-based H-pattern gearbox and street-legal semi slicks on all four corners, the BNR32 blitzed the radial-tyred GT-R record when it went 8.39 at 164mph (264km/h). It’s rumoured that a US-built GT-R has run 8.28 since, in which case the Australian team now has a little bit of catching up to do. Given the way the GT-R seemed to effortlessly get down the quarter, I think it’s only going to be a matter of time before the Australian car steals it back.
  • Like 1
  • 5 months later...
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
