It's what's in the heart that counts. It's like moving Leon from Packenham to Toorak. He'd still be known as Leon from Packy.
I went to a house party in Packy the other day. The guy hosting it knew who Leon was. He's a local legend.
  • Like 1
Guys we need assistance
If you have friend a or 2 coming up with you and they could lend a hand that would be fantastic.
Link below
Cheers Wayne
http://www.skylinesaustralia.com/forums/topic/424957-deca-officials-volunteers-1st-june/
New diff is working awesome, though last night it started stepping out when I put my foot down in 4th on nepean hwy heading home. Still getting used to not single spinning everywhere :P
What are lock stops?
Why were you stalling? Just rip the hand brake and keep your foot to the floor :P Braaaaaaappp!
(for some reason) my car had/has a ridiculously small turning circle. I suspect it was rubbing on the inner guards and bogging it down when on the skidpan at speed. Anyway, it wasnt a happy chappy and my handbrake skillz need work too haha
Because the new suspension has external canisters, we were concerned the steering angle might cause the wheels to hit them. So we installed lock stops inside the steering rack to limit it.
Link below
Cheers Waynehttp://www.skylinesaustralia.com/forums/topic/424957-deca-officials-volunteers-1st-june/
Ok
It's serious time..
We need people to help run the day. What I'm looking for is for volunteers to help run the morning events .
We have the
Skidpan.....need 3 people
Mini..3 to 4 people
Long..5 people
At this stage there is only Anna and myself..
So if you have mates/ girlfriends/ boyfriends / mums or dads coming up they will be helping out ..
If they don't want to help out leave them at home.
Cheers wayne.
  • Like 1
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
