Supporting mods I have are a plazmaman plenum,044 intank,6 boost manifold, 740cc tomei injectors. Could possibly add another 044 pump and surge tank I have to the mix aswell. I have another turbo I might throw on later on down the track to push big numbers. I'm trying to avoid the e85 route as much as I can atm and stick to 98 :) The cars running really rich at this power level aswell
Ahh ok - without E85 I'm really not sure of what to expect from a GTX3076R... somewhere in the low 300rwkw area at a guess.
100% - I've seen a couple of 98 results now and they are doing no better than garden variety GT.
E85 and a well sorted setup would be needed to see the 400kw ceiling mentioned earlier. A lot of boost involved, too.
Raises the question; is it worth it in comparison to a 35R or any number of other available options nowadays?
I don't want to get into a pissing contest but I have seriously not seen anything to suggest it spools as well as a GT3076R. I have however seen a couple of US based back to backs that led me to favor the 35R, hence my comment.
That being said the topic at hand is that (with enough boost) it could reach 400rwkw. A task readily achieved and surpassed by a 35R whilst at a lower pressure ratio.
Later on down the track if I do go down the 35r way can I put the turbo on my current rear housing? I think I read on here they were pretty similiar turbos
If you have the GTX there would be no real need to swap to a 35r i guess! BUT keep your eye on up and coming results as it sounds like there may be some new players in town (I've been so keen watching the discussions on the newer turbos and it seems people are starting to take a punt and try them, i hope they get good results :yes:)
Even better as I'm quite attached to the way this turbo spools up early and hits haha, any chance you can link me to a few discussions on here regarding these turbos?
Some of the info is spread through here -
http://www.skylinesaustralia.com/forums/topic/425145-rb-25-turbo-choices/page-7
There are 2 other threads with similar discussions, it is interesting stuff :)
Too easy, You're a legend mate :)
Haha i just love reading what people are doing, Its good to see new options coming out etc! I considered the GTX but it was all too hard to swap mine etc as i am lazy :P
Did anyone ask if you have a dyno sheet for the GTX? Interesting to see what its doing.
Ill be going in for a retune soon, changing the headgasket due to slight seepage, might bump the boost up abit more, ill post the dyno sheet aswell
Good man! More boost and wake that GTX up!
  • 4 years later...
I know this is an old thread but it's exactly what I'm doing/looking into. I've had 333 RWKW on a GTX3076R (Gen 1) .86 housing at 21PSI in a stock internals RB25. Now inevitably it's failed and I'm rebuilding currently. However since I'm going forged with all the bits I want to push the turbo to it's upper limit. Because I'm doing time attack the higher boost smaller turbo concept for good responsive power is what I'm after. Looking at compressor maps is a worry though, although i cannot find a Gen 1 GTX map on garrets website??? I can find the Gen 2 and the GT3076R. Looking at the GT compressor map the surge line is at about 2.3 Comp ratio which is about 20PSI (ish) the Gen 2 GTX has a very nice wider map area at that section, but is probably not relevant. I also have an anti surge housing though, which is specifically for surge protection and does push that line to the left allowing more boost and a BOV is always run as well, also allowing more... but It's really guesswork it seems as to how far you can go. Previously I was thinking it would run our of air/puff in the high 20's maybe 30 PSI at the most. But now thinking it may fall well short, with no detail on how much further I can push whit the anti surge and the BOV. Any Turbo efficiency gurus? I do plan to break that 400 RWKW ceiling listed here though... If this is the right place I'll update when it's done, if this is the wrong place? Fee free to shift my post to the right area I?
https://www.sau.com.au/forums/topic/421419-timmys-r34-gtt/?page=24
For track work, abandon the GT30 idea.  Retained heat, poor scavenging, and relatively short turbo life are the results you should expect from a smaller (30 vs 35) turbine.  The fast response you speak of may simply result in frying rubber off corner exits, and lower high rpm torque.  Particularly for track, it's got to be able to exhale.
The experiences of 34GEETEETEE tell the story in moving from the HTA 3076 to a EFR 8374.  It's in the turbine.
If you're fixed on the idea of Garrett gear, check what Tim has done with his on the above link, and how it's now performing with a GTW3476.  I wouldn't ignore the experiences of someone who's just done the upgrade, and run at WTAC just 4 days ago.
  • Like 4
to give you a real life example on a track car with 'everything'
I have retained a gtx3076 0.82 rear on my car for near 5/ 6 years now - 4 years of drift and near 2 years of sprint / time attack. I run it on 6 boost 3" exhaust stock engine till now I just put forged in, pon cams and 1000cc ID's 44mm ext wastegate on e85
Ive had no probs with the turbo and its still in great nick, I think there are better options out there now I just don't want to sell this one for nothing and  fork out for a new setup just yet is the reason for keeping it so long and keep spending money just being on the track rather than change :2_grimacing:
in W.A we run pretty smallish 50 - 60 sec tracks not like SMSP etc so response can help anyway or that's what Im telling myself
The response / punch is definitely there I run a pretty high grip rear setup both suspension, tyre and rear wing. Have to control the traction even with all that with the right foot other wise anything under 4th gear still turns the tyres
On hub dyno my last result before I blew the engine was 550hp and 660nm at 23.5psi the tuner say there was prob about 2 more psi in it and that's it. Its full boost by 4000  max torque at 4500 max hp at 7000 That could be limited by a few things though like my 2.5" intercooler piping and only 500 x 300 intercooler (for response)
Just put new forged engine in haven't turned up the wick really yet but on a different roller dyno made 500hp and 585nm on 22psi after a few more track outings we are going to go to 25psi and by extrapolating we expect somewhere around 530 - 540 and 630nm
you'll hit your 400 rwkw @ 25psi ish pending dyno's (definitely hub and i'll achieve this on a roller too)   But I think that's all it has in it and that's running it at 98% type thing
The workshop I'm associated with has done a few RB25DET and RB25DET Neo + GTX3076R .82 combo's, in fact they've got a Neo + GEN2 GTX3076R there at the moment.
From memory the results are all in the 380-400+kW at the wheels range, the highest being 417ish at 27-28psi. The dyno is a current model Dyno Dynamics Dynotech 2WD roller dyno.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
