Yep, V1's, I didn't get a choice in spring rates at the time, so I can't remember the rates, I got the first ever set shipped I think. Just go with the standard setup and they should be very comfortable.
The arm is 28781AQ010 and I got it direct from Nissan for $55 and the blade assembly is AY003H25AR unsure how much from Nissan. You will also need a refill I assume.
Copied and pasted from other thread.
http://nissan.epcdata.ru/stagea/pnm35/6845-vq35de/body/287/?frame_no=PNM35700538
  • 4 weeks later...
http://www.ebay.com.au/itm/181138430477?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
This is the cheapest pollen filter I could find to fit a M35 at about $11 delivered. I fitted the same one a few weeks ago & the quality seemed at least as good as the Ryco one I used before. The postage from the UK only took a week too.
Radiator hoses
Nissan Part No.
21501AL5000 upper hose
21503CD000 lower hose
Gates Part No.
22967 upper hose
22968 lower hose
Oh and Burson Part number for Koyo V35 radiator
NIS081pacak I think.
I was at work looking for the part numbers in the Ecatalog and couldn't find a listing for the 350z's so after I trolled through EPCDATA and then google searched the nissan part numbers those came up in ebay. Can be had quite cheap.
Edited by M35woah
My edit button has gone :(.
But more research on the hoses as Gates had none in stock and would take 12 weeks to get it, faqdat.
So I found out Mackay has got em!
Upper: CH4966
Lower: CH4962
or CH4960
The two lower hoses I believe will fit but CH4960 has a slight extra bend.
Uh oh. Thinking about buying another M35.
Was seriously thinking about a R36 Passat but after closer inspection they are bigger and heavier than both NM35 (200kg heavier) and PNM35 (~80kg heavier).. assuming my specification sources are accurate.
So tell me about these PNM35's lads - what is stock power like compared to a stock NM35? How is fuel economy? I know a lot of you don't care but lets be honest, petrol prices are only going in one direction.
Any things that are highly desirable on them like the NM35? Trans cooler, shift kit, upgraded radiator? Any other common problems?
If you want boostz and powerz go NM35 which I think you know :P
If you want to keep yo keys in your pocket when start and unlock the car and have nicer interior then PNM35 is for win.
Petrol is probably similar, as for shift kit and trans cooler they can be optional, radiator not needed if staying stock, don't have to budget for new tubz or AFM.
Stock power is fine for day to day, but coming from a modded NM35 you'll probably want more.
Get a trans cooler and Scott's coolant mod. You can stick with the OEM radiator without concern unless you are going to boost it of course.
Also, should note that the PNM35's don't have that seemingly problematic pump for the ATTESSA.
Shift kit I hear is good although they do shift noticeably better than the NM in stock form.
Petrol is very slightly better although they are flash tuned if you feel the need (or want).
No real "common problems". Pretty solid car all round and having owned both, can certainly say that the PM is much nicer than the NM.
"If you want to keep yo keys in your pocket when start and unlock the car and have nicer interior then PNM35 is for win."
I cannot stress enough how awesome it is to not have to take the keys out of your pocket... at all.
External lock/unlock buttons on the front doors and hatch. Keyless ignition (although you can still put the key in if you need to).
Also, PM35's look better :P
Yep, I followed yours with interest but I guess if I was going to go with a PNM35 it would be because it's NA. Adding a turbo would ruin the simplicity that I like about them.
What is a reasonably sort of power figure to get out of one without ridiculous mods? Say intake and exhaust with a remap?
Or do they need cams, etc?
Almost nothing. It's just not worth modding one besides some really basic stuff. It's too expensive for the gains compared to a turbo car. Anything from a 350z motors will fit them, so you can go nuts, but realistically, most people are happy to have a bit more noise and breathing. I don't want to give a power figure, cause whatever dyno you go on will be different.
If I was to "finish" mine, it would have high flow cats and a uprev tune. No cams or headers. Mine currently runs 94mph, I think it was, down the 1/4. Compare that to the nm35 numbers in relation to power.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
