  • 1 month later...
Hey all Anyone know what the part number for this bit of pipe that runs towards the back of the engine from the rad or if its an off the shelf part for that matter lol.Looks about 3 or 400mm long, the front of it in the red ring is abit stuffed
Thanks!
They are all a bit stuffed. They don't seem to leak though, no matter how bad they get. That pipe is designed to rust, sacrificial anode as part of the cooling system.
ah yep the thing is the front of it is rusting its starting to leak in the red ring end, got not much to clamp onto now lol
I have some s/h ones here that are quite useable, but get on Amayama and see if you can find the part, it may be cheap... Or not. :P
Bam. :woot:
Water pipe; 14053M
P/N; 21021AQ802
Price; $64.56 usd.
O-ring; 21049
P/N; 21049AE000
Price; $1.10 usd.
You're welcome.
The Russian version of epcdata has all the exploded diagrams, where the English version for whatever reason does not.
Eliminates all the guesswork.
All the prices are through Amayama, not regional Nissan dealers, so I'd suggest getting a few items to make the shipping worthwhile.
From Scotty's post in another thread;
M35 filter: 16400-4M405
Both look identical, and both have 0.1mm larger outlet holes than the stock one I removed.
I will suggest everyone replace the outlet Oring (P/N: 17049-4M400) when changing the filter,
Anyone have interior dimensions of either NM or PM35's?
I have seen them before for other Nissans - diagrams showing the whole car including interior and exterior dimensions.. No idea what manual/catalogue they would be from.
I had a mate translate some of the Stag owners manual. Engine oil change interval is 5000kms, not 10000, and it looks like the filter is every second change. Huge variation in oil viscosities is odd...Diff oil change interval is only 60,000kms, so i know what i'm doing on the weekend.
Going by thet table, it looks to me like the filter is every change (except for the diesel)... as it should be.
The oil they are going by there is the old Nissan semi-synthetic which would need a change every 5000kms.
Depending on the oil, you can actually do 10,000km oil changes, but you won't have much change out of $130-150.
  • 4 weeks later...
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
