Sorry guys its been a little while
Some new wheels
I know they're xxr. But I couldn't afford something supernice
And coming soon thanks to Mr. Evoxenon will be something along the lines of this:
Was wondering who these were going to?
How are they?
Got any pics of light cut off?
Mind asking how much they set you back?
Hey man. When did you see them?
I don't have any pics of light cut off but I can take some.
Way better than stock.
About 500 with parts and postage to Darwin and back.
Cool thanks!
Saw them on the evo xenon facebook page a while back
  • Like 1
I'm pumped. Nistune and id1000 dropping it off on 7th feb for tune
Just completed the major service
Bearings
Seals
Thermostat
Timing belt
Water pump
Usual filters etc
Hi flow panel filter
Fuel filter
  • Like 1
Any final tips before I take the car I for a tune? Am I forgetting anything?
I'm expecting between 250-270rwkw after some research. A bit hard to say as I'm not sure what sort of issues we will run into
Big thanks to Marcus at Jdm accessories and stao!!
And who could forget the mrs for bearing with me lol
Edited by Therealsandybang
Looks like you've done everything that I would recommend. Jez will fit a new set of plugs before the tune.
I think 260-280rwkw is easily achievable, try not to get hung up on a number though, is very easy to do so, just compare how the car feels/drives :)
  • Like 1
you right in the ball park with power figures for the setup you have got, i think youl enjoy the turbo. everyone who rides shotgun in my car loves the punch it has when it kicks in
dyno graphs when you can! :D good luck with it
  • Like 1
I've got one of his newer SS2's with ball bearings and a larger compressor and turbine housing so if you got the same as mine I'd dare say 300 shouldn't be too much of an issue fairly safely. Mine made 320 on E85 with only 22psi so there's lots more in it
  • Like 1
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
