It's more to do with the fact that the shocker mount were never designed to take the weight of the vehicle.
Now that the coil overs are mounted to this spot I have just added extra bracing to transfer the load back to the original spring pocket/body rails.
Got some suspension and other bolts zinc plated and picked up some inner and outer door handles.
Sent Bonneville Consulting and email tuesday but haven't heard anything back yet.
Started fitting the back seat, needed to modify the seat base to fit over the skyline tunnel.
I used the seat base out of a UC hatch that I brought for spare parts but it may turn into a future project and wont need a
back seat. ( S14 front suspension, R32 rear suspension, drift ute, maybe)
The wire frame was a bit bent so it had to be straightened and reshaped over the tunnel.
Rigged up a hot wire to cut the foam.
All fitted up, I will probably only register the hatch as a 4 seater as there isn't mush foam left in the middle seat.
  • Like 1
  • 4 weeks later...
Gave the drive shafts a clean up and some paint.
Removed some of the lip on the fire wall and fully seam welded it.
Added some more strengthening to the front suspension towers to make sure the load is transferred back to the rail where the original subframe mounted.
  • Like 2
  • 4 weeks later...
Have contacted a few engineers to see if they were interested in taking on the project. I've chosen one, now I have to reassemble the car
so he can see where it's at and where to move forward from here. Hopefully he will look at it in a few weeks.
  • Like 6
  • 3 weeks later...
Had the engineer, Peter Turner http://www.techedaustralia.com.au/ have a look at the project.
He is happy with what has been done, he wants an extra brace between the rear suspension towers and I
have to have retractable seat belts for the outer back seats. The car will have to pass the IM240 emission test
and also have a torsional rigidity test. The plan now is to get the car ready for the torsional test then
start the panel work.
Rear seat belts something like this.
  • Like 3
Decided to mount the seat belt reel besides the back seat so they don't stand out as much.
Ground up a piece of flat bar to match the shape of the panel.
Will also weld this comp plate over the outside when the engineer gives me the ok.
Also made up some panels for the back out of some aluminium that i'll cover with some vinyl.
  • Like 3
  • 3 weeks later...
  • 1 month later...
Started fixing the rust in the tail light bucket.
First had to get dogs ok on the tail light bucket from the spare parts car.
Only going to replace the bottom half but had to do a small repair first.
Had to repair some rust in the corner.
Bottom replaced.
  • Like 6
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
