Hi guys my r32 gtr sits around 1/4 on the torque gauge when crushing around 100kms my gtr in NZ and my old gts4 didn't do this unless I had different size tyres on the rear !!
I removed the 4wd controller it had in it and still is sending power when light throttle on the Hilway ??
Any ideas ??
Cheers
Havent checked fault codes yet about to do that now>
Does it return to 0 when you lift off? Probably mismatched rolling diameters.
yip returns to 0 when back off, and I checked tyre pressures and pumped up to a nice firm 38psi 235/40/r18 all round, it does have 10inch wide on the rear and 9"on front.
the same thinig happened to my gtr in nz when had 18's on front and gtr 16s on rear
why does my previous 2 4wd skylines r32 gts4 and my other gtr in nz it would read 0 unless under bumpy roads or accerating or sliping, while cruising at 105kms.
Edited by Tabs
Wrong.
R32 = no preload
R33/34 = preload
No?
OP - it should only send power to the front under heavy acceleration or slip. You're probably wearing it out driving it like that.
yeah im turning key off-on most the time ( put in rwd mode till come to a stop ) to prevent extra wear plus extra fun of rwd :devil:
I have a power fc ecu would that effect the tps for the 4wd??? fi adjusted tps from .9 to .48v
putting the 4wd in diagnostics do you have to turn a screw like the engine ecu or something??
with reds on no led on ecu in the boot (passenger side)
Wrong TPS value can cause shenanigans. It absolutely should be less then 0.5v at closed throttle.
Just google the procedure to put it into diagnostics, or look in the GTR manual. Or, take it to a mechanic who has a good scan tool and just hook it up and surf around in the computers. Much easier.
If you have 10in at the rear and 9in at the front the the rolling circumference will be different - the 40 in the size is a ratio not a height and so they will have different heights.
That tyre size is too narrow for one. I had exact same problem when I put bigger tyres on the rear of my car. Try a different set of wheels if you can, one with same sizes all round.
But, do a diag first (I'm sure there's a procedure around here).
Wrong.
How am I wrong?
Sorry didn't notice that you had the same tyres on different rims. Your rear tyres are illegal in NZ. Minimum for 9in is 235 ( I have 255s on mine) and minimum for 10in is 255 and ideally should be 265 or 275.
If you want to keep the tyres get a set of 4 8in rims or else ditch the lot and start again.
No it shouldn't. It should be 0 until the car detects slip.
Check tyre pressures.
Wrong.
R32 = no preload
R33/34 = preload
No?
Clearly there is some contention about how much front wheel torque is supplied at cruising speed. I have found in the 32's I have run that there is a little supplied at about 100km/h. So I dont think any fault codes will show and I dont reckon there to be anything wrong with the system. AFAIK the attessa works in conditions other than large front/rear wheel speed differentials.
Yes that is true. But the small amount of front torque doesn't register on the gauge. Unless my ATTESSA is not working as well as it should, hence my question of how am I wrong to say that the needle should be at 0 until the car decides to send torque to the front wheels. I may sound like a dick online, but it's a genuine question lol.
When I had 245/40 front and 245/45 rear tyres, every bump sent the gauge to ~10. I had to lift off so it would relax down to 0 again.
Bit off topic, with the R33/R34 GT-R's, does the torque gauge read 0 during cruise, even though there is preload on the front wheels?
How many f*****g times do we have to state that you need same size tyres on same size rims on all 4 corners?
Stretching a 235/40 tyre onto a 10" rim will force the rolling circumference of that tyre to be smaller than a 235/40 on a 9" rim. Result = ATTESA chaos.
The added advantage of this setup is that you can easily even out tyre wear by swapping F<>R at regular (say 5k) intervals.
Yes the R32's system works in conditions other than simply wheel speed difference, but cruising at 100 under light load, nope.
Moderate acceleration without rear wheel slip will show some front torque due to the "G" sensor input.
But as for tyre sizing, I can't understand what's so hard to understand.
Forget theoretical rolling diameters, get the bloody tape out and check circumferences.
It's surprising how similar looking tyres can still be quite different in circumference.
Put the small ones on the front.
And read up on the manual, it's all in there.
Thanks for above comments
I agree with no preload and should read around 0 when crusieing at 100k
Also makes sense about 235 stretched on 10" rims personally I got the car like that and have been destroying the tread to get better tyres as they are a shit compound and I'd perfer stock gtr r32 rims or after r34 gtr rims bbs rims with gold don't do it for me despite what my mates recon thru are worth and how awesome they recon they look !!
Factory gtr rims here I come !!!
There's a sweet little thing called logic;
Sending power to the front when your rears are slipping = sensible, since your rear wheels are slipping...
Sending power to the front when you're accelerating hard = sensible, since your rears maybe be about to break traction because your accelerating hard
Sending power to the front when you're cruising at speed = no apparent benefit, so why do it? They don't do it, except for the preload. They noticed that the R32 system didnt react as quickly as they'd like, so its a bit of a hack to reduce latency. You dont see pre-load on the gauge tho, because its so close to zero.
FWIW, i've never noticed the torque gauge being non zero when cruising.
I've done a lot of messing around the G-Sensor - for sure, if it's not calibrated, it will cause what you are seeing. I've even done it deliberately for some tests. Although if it's as bad as you say, I would expect it to throw an error.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
