Hamstring issue really plays up on leg press, didn't hurt during squats but couldn't do my usual weights. I think it may be due to my right knee bending in when squatting and I'm causing injury. A guy said I should look at knee wraps or bands when squatting, what do you think?
great efforts Leesh. You should be able to focus on the squat technique without those things, at the rep range you are doing.
You still have a shoulder issue? Are you still doing behind the head standing press?
Okay I'll focus on keeping knees out without those. Hamstring hurt walking to work.
Yeah its getting better but not 100% Started shoulder press last night for first time in 8 weeks; changed technique though
Shoulder wise, if you have inpingement , then it's not going to be better doing bench or shoulder press. If you don't then all good but, be aware that rehab work is important. I don't see the rehab in your workout? Perhaps you are doing it but, not writing it down.
Good to hear about technique. I assume you are now doing seated press in font as opposed to standing behind the neck?
no rehab, I'm doing the program Birds just made up for me.. he didn't give me any rehab to do
No I'm not doing it infront, just not going down past the ear
Do you want some rehab movements? Can help there if you like.
Ask Birds to give you an alternative shoulder movement, seated. At least that way you can train full ROM.
yes please, that would be great thanks
Hmm, can't I just do shoulder press seated?
Sure . I will ping some info up later for you.
You can do the press seated , great idea. In front of the head is good for the pressing movement . Find a seat with a slight recline on the back support to make it straight forward.
Here are some that won't mess up your normal routines and will do wonders, injury or not. This is rehab stuff assuming we take it easy. Once there is improvement you can add something resistance wise , like cuban press.
You can youtube search these ones, to make it easy.
Total shoulder girdle health . Do these 3 times a week. Can do them at home in some cases.
1) Serratus Anterior (Activation movements) are in here for you which should help. This sucker stabilses the scapular movement,
a) Scapular pushups. Just a pushup with you extending and retracting the shoulder blades. The movement is shallow( no where near the ground , motion is small) .The arms straight. Do 3 sets of 20-25
b) Single dumbel scapular protraction. Lay on a bench. Fairly light weight dumbell in one hand straight up. Straight arm. As above move the dumbel up and down with the scapular motion. 20-25 reps as above.
c) Scapular wall slides.
d) Prone Cobras held for time.
e) External rotator bands
f) Shoulder dislocates with band or a stick ( can use a barbell if you are strong).
Try these ones for a month.
26/09/13
Squats
35kg x 10
40kg x 10
45kg x 10
50kg x 8
55kg x 3
60kg x 0
Bench Press
25kg x 10
30kg x 10
35kg x 10
40kg x 4
45kg x 0
45 Leg Press
80kg x 10
90kg x 10
100kg x 10
110kg x 10
120kg x 10
130kg x 10
140kg x 10
150kg x 6
Chin-ups
8
7
6
6
5
5
Shoulder Press
10kg x 10
10kg x 10
15kg x 10
15kg x 10
20kg x 5
20kg x 6
Seated Row
20kg x 10
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 1
Hamstring Curl
20kg x 10
20kg x 10
27.5kg x 10
27.5kg x 10
30kg x 6
30kg x 6
35kg x 2
40kg x 1
Bicep Curl
15kg x 10
15kg x 10
15kg x 10
20kg x 6
20kg x 5
20kg x 3
Captains Chair Leg Raises
20
20
20
20
20
Knee Raises
20
Ab Crunches
60
Just saw this.
Either:
a) tie a theraband around your knees and force them out while squatting
OR
b) get someone to wrap a band around your leg (just above the knee) and pull it towards them, while you lunge (they should be pulling the band from the inside edge of your knee). Force your knee outwards (track knee in line with foot) so that it doesn't fall inwards.
I would recommend the latter
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
