I've been driving more than usual lately, and using more fuel, so I've been taking more than a passing interest in prices.
In particular, while the servos advertise their cheapest price in huge letters, they kind of "forget" to advertise the expensive 95 or 98 octane stuff we actually had to buy.
So, this is a survey of advertised vs actual prices for the fuel we need....feel free to add in this format:
Brand, Location, cheapest price on sign (usually e10 91 octane), 95: margin 98: margin
Interesting to learn that different brands, and even different locations on the same brand charge different margins.
https://www.sau.com.au/forums/topic/428718-servo-margins-for-9598-octane/
Some data:
BP, Pymble, 91: 142.5, 95: +10c 98: +16c
Shell, Manuka ACT, 91:148.9, 95: n/a 98: +17c
Caltex Concord, 91: 157.9, 95:+13c, 98: +17c
BP Marulan, 91: 157.9, 95: +12c, 98: +18c
Caltex, Majura ACT, 91: 157.9 95: +11c, 98: +15c
I'm really surprised that the Pymble BP is cheaper than the rest. Must be on the cheap day of the week compared to others.
I find that BP is usually at least 5c more than either of the Shell stations on Ryde Rd near Gordon and one in Macquarie Park.
I'd also be interested to see if the PULP 98 fluctuates as much on weekday rates as the e10.
as the base price(e10) fluctuates, so does the better fuels.
  • Like 1
Guys, the intention of this thread was NOT to talk about the base (91/e10/whatever) price, because I'm sure we all know that goes up and down based on fuel companies' pricing decisions (and sometimes exchange rates, oil prices and wars). Like Luke said:
The point is the more often hidden/obscured difference between the base price and the stuff we all have to use. Based on what I've seen so far, I think we will find cheaper brands and/or locations by gathering some proper information.
I like how E85 follows the normal fuel price minus "x" amount. The last time I looked, I'm still paying the same for corn and sugar!
Yep, exactly the same scam really...it's pretty sad, but they will all keep doing this unless we pay attention to the behaviour!
I think it's fair enough to suggest that 7Eleven policies are assisting (somewhat) to keep margins lower through competition.
I would use their 98 in the Foz XT and compare with BP/Shell in the GTR. Depending on what car I was filling at the time, I was either smiling or grumpy.
I'm a little surprised no-one else is interested in collecting data....anyway here are 2 more from this week:
United, Rozelle: 91:148.7, 100:167.7
Caltex, Majura ACT: 91:157.9, 95:168.9
And here are some sample graphs of the data.
Thanks Ian for the link to base prices, here are the numbers for Sydney from that site:
What do they say together?
Buying on 98 from BP Marulan on a Saturday (175.9) would cost you 21c (12%) more than buying 95 from BP Pymble on a Wednesday (156.9).
Who wouldn't want to pay 12% less for petrol?
I fill up both my daily cars with E10 and had with my previous dailys so the E10 (advertised cheap price) is what I go by. I drive from one side of Sydney to the other and what my issue is the amount one servo can charge in one area compared to another.
Eg: SW Sydney compared to the Northern suburbs.
There is always a BIG difference in price between the two, as much as 20+ cents a litre on some days. Now there are possibly dozens of reasons why but I can bet none of them have to do with the price of oil.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
