Sorry to hear it....
Argo rods too, bummer. I'm running Argo's in mine so hopefully I don't meet the same fate!
I've seen crank oil galleries blocked from a ball of sealant that has fallen off the sump to block join over time. It's very easy to overdo it went applying it.
Other than that the fact that it happened on cruise is a worry. Hopefully there is a clear cut reason as it sucks arse when a motor dies and you don't know why!
Im going to pull the oil pump apart today, but i was still getting normal pressures, so I doubt its the pump. Only about 2,000 miles on her since the rebuild. Havent even turned up the boost :( I was fun as hell at 12psi though.
Edited by ZT-R
I wouldnt think it would get any better the a R.I.P.S. build. Everything is out now, so its no longer a rips :( Anyone can assemble them, but not to his specs and attention to detail, Although I think i will debur the inside of this block, its ugly and quiet scary looking.
The number one piston is out of round by 8 thousandths. and the crank is egged. So for sure needs a new crank and rod.
Anyway, more disassembly pics.
IMO the mains dont look great, but its hard to tell from pics, the fact all the big ends are trashed points to oil issues, could there be contaminants in the cooler etc? have you asked rips? Theres not somthing funny like oil thermostat or oil filter block incorrectly plumbed? how do the cams look?
Edited by Adriano
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
