I have 18x9 inch rims.
Deciding what size tyres to get.
Car is lowered on king springs
Tending towards 235 40 and 255 35 OR 225 45 and 245 40
Give me opinions but I want pictures to help me decide....
I like the look of stretch to be honest but want something "reasonably" practical as well.
PICTURES ARE KEY..so put them up if you have any (please)
More so than the size, will be the tyre brand, and type, that will affect the look. Example; whether it has a rim protector, sidewall stiffness etc.
Here's a picture of 215/45/R17 Federal 595's on 9.5" TE37SL's. Notice how the Federals are quite 'square' and don't give much of a stretched look.
235/40 on 9" rims is a mild stretch and by far the cheapest. If you want mild stretch at a reasonable price there is no other option worth considering, all round.
It's also the right diameter. Otherwise 235/40 & 265/35 rear is a good mix, but 265/35 is not stretch on a 9" but is a good vertical fitment (you'll need offset over 30 to fit).
265/35/18 Falken Azenis on 18x9
But, the tyre design does play a part.
good choice, not a fan of stretch.. if you want a smaller tyre, run a narrower rim
255/35/18 (what I had before I put those Falkens on) were slightly stretched, 245/40 was even more (both KU31). 235 would be stretch regardless of tyre design lol. All down to preference.
265/35/18 Potenza TS-02 on same 18x10. Note they have rim protector, which gives a more stretched look.
Tyres are designed to fit a particular range of rim widths. If you "stretch" a tyre, then the rim is probably not within the design range of the tyre. If you run a tyre on a rim that it is not designed for, you run the risk of having insurance invalidated - car will be unroadworthy. And frankly, any tyre technician who stretches a tyre onto a rim should be shot.
Frankly, if you only want, say, a 235 tyre on the car, then get rims designed for a 235 tyre. Don't try and "stretch" them onto a rim designed for a 265 tyre. We'll all be safer on the roads.
I would like to clarify a few things with you.
Please do not take this the wrong way and THIS IS NOT A PUT DOWN...and while I respect that everyone has their opinions.......
.........However since you were quite "animated" with your response I would like to point out that every single manufacturer / website or person I have interacted with have mentioned that a 9 inch rim should have anywhere between a 235 and 255 tyre !! So first of all running a 265 on a 9 inch rim does not meet your own definition of "roadworthy".
Richards tyrepower suggested a 225 (without me saying a word about any size) just for your information and I have the email correspondence. So please do not shoot them or we will know it is you !! hahahaa
Anyway you rightly pointed out that insurance will be affected with the wrong size tyre and I accept that and thank you for your input.
I have ordered 255 35 18 Ku31s from Tempe ($200 delivered) for the record for the rears. They are out of the other sizes at the moment.
Individual tyres will have a range for them. BTW he didn't say that 265 was recommended for 9", but if you see my picture above, it gives a vertical sidewall.
I would stay far away from a tyre shop who says 225 is recommended for a 9" wide wheel.
The picture is 10 inch..i have 9 inch....unless you mean it will almost overlap..and yeah like i said iv already got 255s for the rear
TERRY THANK YOU :)
Edited by jez NF
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
