bit of an usual one guys but here goes....
So I have a R34 Rb25DET Neo with Tomei spec 2 cams, cometic triple layer head gasket, ARP head studs, high, mount, greddy plenum, pfc usual kind of stuff everyone has now days...
I was driving it yesterday down the fwy, when I pulled off the fwy I noticed my temp was at 106, I wasn't far from my mates house so I kept driving to his house, keeping an eye on the temp and it wasn't increasing as I was moving, I know this is still bad.... Anyway as im just about to pull into his street I notice my oil temp is almost maxed out on my temp gauge. So I shut the motor down and let it cool.
We found the cause of why the car got hot, simple coolant leak under plenum, repaired leaked, refilled with water, rebleed system and all seems fine now. The problem I am concerned about is now when it idles it seems to be a lot lumpier then it ever was before with the cams. I drove the car about 40km home, cracked gate a few times and all seems to be as normal.
I am wondering now if maybe serious damage has been done inside the motor after heating it so much? I am doing to dump all oil and water this week and change out the plugs, prob do a compression test also just to make sure all is OK.
Any ideas? anyone heard of this before? Should I check anything else?
  • Like 1
https://www.sau.com.au/forums/topic/430498-very-hot-neo/
If you had local boiling in the head, or even if it was just dry in the head because you lost some coolant, then the head could have been hot enough to warp. I'd consider taking it to someone you trust to have a once over and perhaps look for any tell tales they might notice that you don't that there is a bigger problem than you'd hope for.
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6976340
It may have been alot hotter than the gauge says too, if it's lost enough water to overheat there may not have been enough water left in the system to give the sender a decent reading, probably why it didn't go up more as you drove further, doesn't sound good at all
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6976775
Doesn't sound good man. A note whenever the engine is running hotter than usual is to switch on your heater to max heat max speed. Ill keep an eye on this thread. I suspect the head may have been exposed to too much heat for too long and potentially warped which is a common effect of overheating. I just dont know how you diagnose this.
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6976809
Just an update for those that are intrested...
So we did a comp test on the motor last week, found cyl 3-4-5 all down around 115psi! Straite away suspected warped head, so we removed the head and sent it off for X-ray, preasure test and skim. Found head warped hard... Took 3 skims to get flat again but lucky that was the only damage done! No damage to valves and no cracks in the head or damage to the cams so stocked with the results.
Checked the block with a straite edge also just to be double sure and all is fine! Thank f@ck!
I have bought another triple layer Cometic head gasket but after I did I was told u don't need to replace after 1 use specially with the low ks mine had done (approx 3,000)! Does anyone know if this is correct? I'm fitting the new one now anyway but just intrested in finding out of this is correct...
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6997054
As I suggested in another thread, it's not a good idea to skim a warped head. Only the face gets skimmed, leaving the cam towers in a slight arc (might work for a pushrod engine, but not for OHCs). I believe the correct procedure is to shove it in a press and press it flat again - with heat if necessary.
Last head I warped is probably now a boat anchor.
I reckon if you measure the head thickness at both ends and in the middle, you will discover that it is thicker in the middle.
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6997466
It depends where the temp was taken from, and if there is no coolant flowing the engine temp could have been much higher...
I have seen 130+ degree water temp at the track without issues, other than a little flash boiling around the bore. I have alloy block and heads though, so the expansion rates are probably closer than cast iron/alloy.
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6999539
I have a greddy plenum so the water temp sensor remains in standard location. The hose on the cold start under the plenum was we're the leak was, the main supply hose let go so it pumped all the coolant out very quik...
I don't think the head was warped too badly as the head guy at first said it doesn't seem too bad with the figures I gave him. I will measure as u guys suggest but I also have arp head studs so maybe I can just tighten it down and pull back down flat?
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6999861
No idea, didn't measure before sending off!
Can't have been too bad, car was running ok, no water in oil and comp was only down about 15psi...
I'm going to put it back together with stock cams see how it goes, if its no good ill pull it and buy new motor otherwise ill just screw boost and try get some fun out of it before it breaks!
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-7003927
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
