after 8pm and if im online, im going to be grinding away at "down the drain" race, 1 lap races and ill most probably invite crew members most times, jump on board for easy cash.
mix it up with different car classes but its a bit tediouse. good cash and good experiance though, best i have found so far.
can be fun too.
The Stimulus Package only applies to players who joined Online in October, only.
need to get as many SAU people playing "down the drain"
make it a one lap race, over and over as you get about 3-15K every race, which is like 3 mins long. great to level up and get cash!!!
You all on XBOX or PS3?
I am on PS3
Rank 23 atm.
ps3
ps3 and yes i joined in octoBER!!
WINNINGIN I SHOULD HAVE IT
Cool!
I might have to join the SAU Crew or just Invite you both if I wanna do a Mission.
What's your Gamer Tags on PSN?
PM if you want.
I mainly do Solo / Invite Session as I am wanting to level up.
I do them to unlock more car mods. My pink scooter and Sandking XL need some more loving.
Super pissed off at some of the % spawn rates for average cars. Blista's are next to impossible to find if not low level, even in single player. The commercial vans are cool too, slammed on tuner wheels with rollbar and white wall tyres. bawlla
Cool!
PM if you want.
psn nick is: emmadamo
yes mine and my partners name! add me up guys and gals
    • So I put it to 3bar (43.5psi) while priming. It stays at 43.5~ as I crank shakes slightly. Ive also tried dropping pressure to see if that changes anything. I replaced the fuel dampener because I was troubleshooting the system along with the stock FPR (swapping them one by one to rule them out). But i only got up to changing the dampener and it started running again. Injectors are stock second hand. I did a bench test on both my original ones and the secondhand ones. The second hand injectors I have in the car now spray slightly stronger than my original injectors.
    • I knew Andy from about then, it did some cool stuff. By 2005/2006 era, he also implemented closed loop ignition timing tuning. In 2004 it was pretty cool, being with him when he was doing automated fast self learning tuning!
    • Im No tuner but…. im running a 25det with north of 600wkw at 9000rpm e85 and water meth. G40 1150 on 32psi. Having a real built head will flow a crap ton more power but you being stuck at 7600 won’t be helping at all, throw all the boost you can and nothing will happen. Solid lifter and 9000rpm is the only way,  I have built my motor 3 times, not from engine failure but more along the lines of my failures in not understanding engine parts better, basic phrase to help, “block hold power”  “head make power”
    • What's the fuel pressure while the car is cranking? Curious, why did you replace the fuel damper? What injectors are you using, are they brand new?
    • I think it's terrible value, it should be half that price IMO. And I'm known as someone who will unironically suggest the GTIII-SS on the RB26 if you have very specific requirements. The GCG RB25DET "hybrid turbo" is 1/3rd the cost of this GTIII-RS kit and sounds like it should fit with zero modifications. Talk to Hypergear as well, maybe they can do something that fits your requirements.
