You are looking at spending 10k to have it pull hard..
You will spend a lot less if you get your stock turbo highflowed to the right profile, it will definitely give you the pull hard effect and will cost you a lot less.
I reckon a Hypergear G3.5 highflow will do a good job of the desired task, the delivery will give monster pull without being a pig to drive.
Before you ask, you will need a full 3" TBE, FMIC, fuel pump, injectors and an ECU at a minimum.
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069538
It's not rocket surgery.
It's not brain science either.
GTScotT is offering some sound, experience based advice. He's also considering the driving outcome and financial aspect of things.
However if you are chasing a 500rwhp setup you won't likely get there with a GT30 setup. Go the GT35 and be mindful of people's comments to this point.
  • Like 1
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069729
At the moment no one has given me a answer or opinion on what one would be more suitable
Yes they have...this:
and see also:
Look at the rb25 dyno results thread. It's not rocket surgery. People don't have to tell you what to do, you can figure it out yourself sometimes!
and forget the GT35
  • Like 1
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069772
3076 56T with a .63 on E85 hits like a sledgehammer...
the hypergear stuff in same size are a more linear pull and deceptively quick, but probally faster no doubt
guess it depends what you after, i have no idea what a 3450 feels like on a rb25, only 25/30's and 30s's
guessing boost response would be fairly bad on a manual
cheers
darren
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069900
Glad you put that 3 inch cooler piping, talk about overkill. You can make an easy 300kw on 2.25 inch piping.
Stop slapping parts on and read, there is so much information here you should be able to work out what you need, then see if you can go for a spin in a few members cars to get a feel for the response. I am guessing the GT35 will be a little too laggy if you plan to drive it daily.
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7070093
Read this thread - ultimate RB "pull hard" setup, make numbers in the range of GT35R peak power but spooling similar to the smaller GT30 range turbos:
http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/
  • Like 1
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7073476
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
