This one
5. Drivers and passengers that open their car doors onto other people's cars.
I now have 2 dents and one paint scratch
(respond in kind with knee / remove their rear view mirror - when confident it was the car still parked next to me)
This one
i had my falcon for less then 3 months (after buying it new) when I ended up with a dent above on the rear guard, still haven't had time to ring a pdr bloke to fix it
And unattended children running amok at car shows. I saw a kid dent a show car by heavily leaning on a car one time. Parents....? Nowhere to be found!
There was a car show at Sth Windsor recently and a yellow 32 was on display. Kids climbed all over guards mother was too busy on mobile and could see what they were doing. Solution: went to P/A and got them to page the owner. Lady actually said to the owner with now waved and dinted guards "Don't display it then". OMG!
  • Like 1
This one
I had little shitz next door lob a basketball over fence and onto car roof. No apology, big dent. Actually asked for ball back too - I gave it back, although those car roofs are very sharp ;)
Door and boot slammers are one of my pet hates, along with everything else. really dislike people that lean/sit on others cars.
I dislike people that go in the left turn lane with green turn arrow at traffic lights, And just sit there so they can go striaght ahead. meanwhile everyone that wants to go left has to sit there and wait for d8ckface to move
Edited by dyl33
  • Like 1
Could not agree with this more. The next mod I want on my car is a cannon/big calibre gun just for these morons.
Also one of my big pet hates is those idiots (usually P platers, sorry to have a go but usually they are) that rev their shit cars, usually magnas or integras in my experience, and try and race me. Why would I waste the fuel when I have 220rwkw in a modified skyline and you're lucky to have the power of 3 harnessed children at the wheels, I KNOW my car is faster
I hate people who drive up beside a turning lane and cut in right at the front instead of waiting like everyone else
^ must be ex Canberra drivers. Every morning on the way to work I see this.
It makes me mad as hell.
and you know what else erks me. The silly mongrels who let them in.
I have them do it to me in the truck all the time , I never let them in
I HATE this too, and also those clowns that wait right up until their lane closes before they merge. Screw them, if I have enough courtesy to prepare myself to change lanes from 100m before it closes, what do they think makes them so f'king special? AggroDave and I were talking about this today from when I continually held off some clown on the M4 who thought he'd be able to merge in front of me, then got the shits when I wouldn't let him in.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
