Currently its;
Tein coilovers, 8.2 front, 6.4 rear corner weighted. Front height 350mm, rear 340mm.
Whiteline adjustable sway bars, front full soft, rear full hard.
Whiteline neoprene? pineapples, IIRC in "traction" position. However, one of the factory subframe bushes is leaking.
Front 3 deg neg camber, rear 1.25 deg neg camber
Nismo radius rods with superpro adjustable bushes
R34 GTR rims with R specs
Ebay attessa tweaker
The car still understeers too much. What's the next step to address that? The car is not a daily anymore so comfort is less important. I've been thinking about;
- Rose joint radius rods (GTSboy seems to be a fan, understood they're not road legal)
- Softer front springs - maybe 7kg? or?
- Alloy pineapples (so the leaking factory bush no longer matters)
- Roll center adjusters - will this help front end grip if i just add them on the front?
Comments?
https://www.sau.com.au/forums/topic/434076-r32-gtr-suspension-setup-whats-next/
Yup. More caster needed. Will give more camber in turns. Softer front springs will certainly help grip, but at the cost of body roll. Whether that is important will really depend on your application. If you're driving road/track with rapid left-right-left direction changes, you will dislike having more roll. If high speed sweepers is more your thing, then provided they're not too bumpy you'll benefit from softer front springs (and damping adjusted to suit).
Fixing up the rear subframe bushes will not improve front grip, but may increase your confidence, which can be good or bad depending on your actual talent level!
Roll centre adjusters? Dunno.
Things that affect understeer:
reduce understeer by:
- front tyre pressure : higher
- rear tyre pressure : lower
- front tyre profile : higher
- rear tyre profile : lower
- front camber : more negative
- rear camber : less negative
- front springs : softer
- rear springs : stiffer
- front bar : softer
- rear bar : stiffer
If I go more castor, will that cause upper control arm bushes to flog out? Lots of people seem to have problems with them, but i've been ok so far on stock castor (noltec upper arms). IIRC stock castor is in the 3-4 deg range right? How much do you suggest?
Would the extra rigidity of the rose joint arms be beneficial even it i dont pull in more castor? (less loss of dynamic castor?)
AFAIK they're stock diffs. I *think* i can notice the rear tightness in carparks, but could be my imagination.
Re tyre pressure - does that imply I need to measure temperature across the tread. or just play around with it to see what happens?
Thanks!
With the attesa tweaker, have you read Julian Edgar's article on his early attempts to build such a device? Quite interesting how attesa works.
After what I said above, I would recommend taking a bit of camber out of the arse end, to 1, maybe even .75 -ve. And pump an extra 2psi into the front tyres.
Where abouts through the corner is the car understanding? Entry, mid, exit
I'm going to say entry. It could be I dont really know what im talking about.
Toe is zero front, and IIRC zero at the rear too.
BlindE - i read an old ?autospeed? article about it, is that the one? The tweaker makes a huge diff compared to stock. Don't know how much better the ruzic etc ones are. However, there's too much understeer when no power is applied.
Thanks!
I was going to reply to this and then got massively sidetracked. So there are a few replies above this one that cover a lot of what I was going to say. Basically you need to wind on as much caster as you can. That's typically in the 5-6° region. I don't have my catser rods as short as it is possible to make them because I feel it makes the front suspension bind up too much, plus I get some rubbing.
I also suggest a little toe out. Certainly up to 1° at the front will make it more willing to turn in. It will not actually reduce understeer once into the corner though.
Toe out at the rear will make the rear more willing to come around. So it will be less settled, more twitchy and active. That will make it behave as if it has less understeer. Whether it is faster or not will agani depend on how good you are I suspect.
For all the castor enthusiasts (fkn drift has ALOT to answer for, this being just one thing) a stock 32 GTR runs, wait for it: Fk all camber. 3 degrees and forty minutes. Trying to run more puts the top, outer link out of alignment and if you run a rose joint castor rod you will screw the bushes once per track day. If you want more castor you need to modify the top link and the mounting point on the chassis not just wind up the rose joint as many people do.
All castor is is more camber when the wheel is turned. As most GTR's are underbraked anyway you dont need the castor to pick up the camber, you can just run more camber. It is just that the drift nuggets like it as it means they can let go of their steering wheels and freed from the muppet behind the steering wheel their cars will return to travelling in a straight line.
If you want a gain there are two things I would do as a first step:
1. Replace the the stock upper link mounting bracket with either a Nismo item or a stock item remanufactured to be like the Nismo geometry or run one of those top links with the bearing in the middle of it (which I dont much like but each to their own)
2. Soften the front spring.
Put the pineapples in the normal position, not the traction position as the thing shouldnt oversteer on corner exit anyway. If it does push more torque toward the front with your attessa do hickey.
Bottom line it is a GTR and with such awful weight distribution it will understeer. You have to drive around it and make lap speed by a late turn in and early power down rather than trying to flow the thing with bulk speed at the apex. Dont overdrive the car as that prompts plough understeer mid corner and canes your lap speed.
Edited by djr81
Agreed. We stated that some extra castor will help, it's not like we said to wind in as much as possible, even couple of degrees would be of benefit. Too much castor on a drift car equals positive camber on the inside wheel at opposite lock anyway. And although its been three years since my last drift day, I do try my best to 'feed' the wheel as much as possible, but i'm not as good at it as I would like to be.
considering how cheap gk tech front RCA's are theres no point in not trying them out
you wheel track also plays a part so make sure front and rear is equal or front has more track then rear
try stock gtr front sway bar and i've also noticed once changing my worn rear sway bar bushes this made the car more oversteery
edit: make sure current castor settings are equal ( loose bolts, bent parts, bent car) as if not this also deals out understeer
Edited by Dan_J
^ It's a valid point. Hence why I don't have my caster rods wound up to drift spec. But a little extra caster is free grip in corners without wearing out the insides of tyres while driving straight - which is a priority for my daily.
A little extra castor drags the bottom of the front suspension forward. A couple of degrees turns out to be quite a distance. So what do you do to compensate for that? Most people do nothing and scrape the tyre on the front of the guard liner but it should also be adjusted at the top by reducing the trail on the upper link. Unfortunately there isnt anyone out there making a decent upper suspension link any more.
Oh and roll centre adjusters arent easy. They are a pain to install given how difficult it is to get the old stuff out and apart. Particularly at the rear.
What would you go for? 6kg/ 7kg?
Whole discussion is rather mute without knowing the tyres you run. What R-Spec?
Its 'moot' not 'mute' :) Also - I would have thought that the type of tyres could not effect under/oversteer balance - am i wrong?
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
