Hey guys. Ive done pretty much all I can to my R33 GTST. as far as bolt on mods go. Its currently putting down 250rwkw. Doin the last little job next weekend and then I gotta retune it. Pretty sure ive gone as far as I can with standard internals. Im expecting around the 270kw mark after I retune it. Is there any other uselful mods u guys can advise me to do, not for power gains, but just to make it run a bit better? (help the thing live for as long as it possibly can). I dunno if io posted this in the right place, but im open to suggestions anyways. Thanks guys
https://www.sau.com.au/forums/topic/435064-what-else-can-i-do-to-my-rb25/
My tuner advised me to replace the exhaust housing my hi flowed one. He rekons most hi flows should get about 250rwkw, but with the GCG the standard exhaust housing is a lil restrictive. I got another for it. Im gonna replace that and retune it. He rekons hes tuned cars that got 290atw from that turbo, so I went that option for now just coz its cheaper and easy
E85 is about the only thing to make it last longer.
Imo 250 is prefect for the street, why not just leave it and enjoy it? Since my car started making 260kw I've actually gone "you know what? this is more than enough power for the street" The turbo comes on like the stock one but makes 260kw with no lag, what more could you want?
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
