Why is this still unresolved? Almost at two weeks later ffs.
It's not unresolved. It's just that RBR didn't like the resolution.
But RBR have been testing meters under FIA observation in the meantime, and have "acquired a number of new fuel flow sensors and will work with the FIA during the (Malaysian GP) weekend to find one that is accurate to the satisfaction of both sides."
They're less likely to do it again this weekend because they have no real hope of keeping the Mercedes powered cars behind them on these long straights unless Renault has made big gains in their engine POWER spec - oops did I say power? I meant reliability - because those are the only changes allowed now, for improved reliability. yeah right... whereas in Aus it was worth the risk because it is a difficult track to pass on.
Edited by hrd-hr30
Slightly worrying that the sensors need to be tested on the car to find an accurate/acceptable one.
They are all tested then an offset applied (eg its 2% over reading or under reading or whatever) and then used. It is easy to say it should be perfect but nothing in this world ever is.
The sensor manufacturer says "52 per cent of its meters are with a 0.1 per cent accuracy reading, with 92 per cent within 0.25 per cent". As you say the offset is applied to level them out, so all cars can use the same mass fuel flow.
"the teams have accepted that when they are alerted to the possibility the sensor could exceed the 100kg per hour rate at peak flow, irrespective of what their own data says, they have to peg back their rate slightly to ensure there is no breach of the rules." Well, every team except one that decided to ignore it and the FIA when fighting for position with a more powerful car...
(quotes from http://www.autosport.com/news/report.php/id/112973)
Edited by hrd-hr30
Well it does because if it was a bullshit number you can understand why they reacted in the way they did.
EG:
FIA: "We now want you to reduce your fuel flow by 5%"
RB: "It was 0.2% on Friday your numbers are clearly rubbish. Get stuffed."
FIA: "Resistance is useless" etc etc*
* Yes I am likening the FIA to the Vogons.
Edited by djr81
EG:
everyone was in the same boat. Other teams adjusted their fuel flow during the race according to what the FIA were seeing from the sensor. Some even chose to run well below the sensor indicated maximum flow to make sure they didn't exceed it. Only one car refused to play by the same rules and the same calibrated/corrected meter everyone was using. .
Edited by hrd-hr30
Half expect RBR are willing to fall on the sword early and bring the BS out in the open. I hear what you are saying about others obeying...but for all we know RBR may have been the worst example being asked to forfeit 4% power vs lesser amounts for others cars.
It matters little, the fact that many cars were all winding back performance, likely to all differing levels then why even have qualifying or practice sessions. Just have a raffle and fit random flow meters to the cars and watch them jockey for position in a race as the FIA tell them to slow down or allow them to speed up all on different levels ...retarded.
I am no fan of RBR...but good on them for busing balls over this now and hopefully we will avoid the farce of inaccurate instruments hurting a percentage of th efields performance over a race weekend, because....lotter dip of erroneous sensors says so
  • Like 2
Kimi has made a great improvement in the Ferrari. Mercedes having tyre wear worries
Might be an interesting weekend after all
yeah looks like it was more than just the new braking system....
but it sounded like he was having tyre issues on the long run too wasnt he?
hopefully the ferraris can take it to the mercs!!!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
