Britney gets pole, but only really through a technicality. And then celebrates as if he didn't screw up others laps. They need to bring in a rule where if you cause a yellow with less than 30 seconds to run, or after the session has ended, then you get a penalty.
No they don't. It wasn't on purpose, that's racing (or qualifying in this instance).
I agree that the celebration was a bit much though.
lol that is one of the stupidest things I've ever heard. Let's penalize people for pushing it to the limit in Q3 while trying to get pole.
Rosberg should have stayed right at the end of that escape road as his session was over anyway with only 30 seconds left in Q3 and not enough time to start another lap. With him at the end of that road the yellows should have been cleared and Hamilton would've been able to complete the lap
Doesn't take much for the douchebag in Hamilton to come out!
Rosberg scored 2 little victories there - one over Hamilton for pole and also over Hamilton mentally - he's no poker player! The last thing you'd do is let the other guy know how pissed off you are like that - or carry on like a child in the press conference broadcast to the world!
I wouldn't be surprised if Hamilton does something stupid tonight, or makes one of his trademark silly mistakes...
I don't see why it's stupid. Had he caused a red flag he would've been penalised. Had he been going slow and blocked people he would've been penalised. Had he gone off and pulled back in front of someone while returning to the track he would've been penalised. But sitting a little way down an escape road and then reversing onto the track, while causing a prolonged yellow flag is ok cause he was "just having a go"? Might as well stop penalising people who take another car out when trying to overtake under brakes, because "they are just pushing hard to get a position".
He didn't go slow and block anyone, he didn't go off and pull back in front of anyone and so on... I said he shouldn't be penalized for pushing hard for pole, and f**king it up.
He should probably have copped something for reversing up the escape with the intention of rejoining as he was well aware there was 30 seconds left, and that he could not get around to start a new lap..
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
