3.5L runs a different plug, and has different CAN protocols. The 2.5dd, 3.0dd and 2.5det all run the same ecu plug with slightly different pinouts.
Most 3.5L ecu's will work, without cam actuation. If you want the cams to work, you will need to reprogram the frequency/degree and self learning, which only the Haltech Elite can do afaik, and without Haltech support you are up the creek (as Mercury found out the hard way). Short story- Don't bother at this time.
  • Like 1
  • 4 weeks later...
Hi... I'm Rick and I'm new to the stagea forums... I have a a m35 arx and.am about to start modifying it... As for ecu options I have read all the covered options and decided to do some searching of my own... The only other option I found other then what has been covered is something called UP REV OSIRIS TUNER... I believe rev zone are the dealers in melbourne for this. I have spoken to them and they want to see my car and plug in a diagnostic to see if they can licence the ecu... Anyone been down this path???
The only ecu options available and proven is the Emanage piggyback, or the HDI Maxrom afm signal bender. (unless you can find a discontinued VQ25det specific loom for the HKS Fcon Vpro. This is by far the best option, and the most expensive)
The Adaptronic has issues, as does any other standalone at this stage. Personally it's hard to go past the Emanage Ultimate in Melbourne at least, as there is a tuner here willing to touch it.
The Osirus dongle can't read our map, it just comes up as jibberish, corrupt data, as ours isn't the same OBD2 protocol as they are used to dealing with. We tried this path years ago and nothing has changed to my knowledge.
What are your power goals? I can suggest the best option for you that way.
  • Like 1
  • 3 weeks later...
Just translated it..
For that price you may as well just get an emanage..
Description of item It becomes NISMO computer.
Dirt.
It is not failure of the coupler.
There is no problem with the mounting portion.
Data is unknown.
Seal is not affixed to the full.
Operation verification ending.
There are a small wound. Detailed condition, please refer to the image.
Edited by Reaperblitz
Dirt.
Data is unknown.
The nismo is something you want to use combined with the emanage. It fixes a few issues the emanage can't. Speed limiter and throttle issues etc
80000YEN is not good deal for nismo ecu, it could get an e-manage with tuned around 1300AUD
I don't think you fully understand just how different a Nismo ECU is, compared to a stock one.
I am also using aftermarket ecu right now. I just want to say the low value compare with the high price. I was not saying nismo ecu equal to emanage.
i would agree with this, i don't think its worth the price
If it was it would be sold already.
Interesting that the emanage is still the most capable ecu on the market at the moment, and the only things it doesn't get rid of is the Speed and rev cut. If those worry you, then any way around them will be expensive.
180 km/h limit ?
Damn, I was looking forward to testing my stock brakes and suspension at 200 +
you can buy HKS SLD (speed limit defencer) to unlock 180km/h if you can't find cheap aftermarket M35 ECU.
Agreed, mine works well, but understand you are cutting the main CAN communication lines to install it.
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
