have just put my engine back into my r33 list of mods below. the problem i'm having it it has nearly no vacuum at idle when it idles at 1500rpm. then for no reason, the rpm will pick up and then idle at 2200rpm.
i have carried out a smoke test on the engine with no results. with the engine running, i have sprayed everywhere around anything that can potentially become a vacuum leak or cause one. e.g (injector seals, plumbing fittings under plenum, around the valve covers, the brake booster, the throttle body seal, the gasket faces) i have blocked of the hose to the brake booster to eliminate the booster, no change there. out of ideas, can anybody help me please. i have spent over $30k on this motor, i need to get it working, really getting frustrated. thanks
engine:
rb25det head full cnc with vg30 over sized valves 1.5mm
custom grind cams from surecams (297 in, 310 ex, 10.2mm lift)
hks adjustable cams gears
plazmaman plenum
plazmaman 75mm billet throttle body
40thou over JE customs pistons
perfect circle rings
brian crower rods
nitrided and heat treated crank
N1 oil pump
davies craig electric water pump and fan controller
hks 1000cc injectors on rb26 hks top feed rail
hks t04z 0.82 a/r rear housing
6boost high mount manifold
hks 50mm gt2 wastegate
plazmaman fmic
GZ motorsport vacuum pump with relief valve
fuel system:
bosch 040 intank
2L surge tank
2 x bosch 044 inline pumps
twin lines to fuel rail
aeromotive fuel reg.
Yeah have checked that also, all spot on. The inlet cam is advanced 3degrees and the exhaust I'd retarded 2.5 degrees. Even with the vacuum pump relief valve done up all the way to hard, it still only pulls -2 inhg, and changing it does nothing. Should see about 5-6 inhg at least without the vacuum is this more or less correct?
This and did you degree them in or did you just bolt them in and think whatever the cam gears say is correct?
Big cam durations=little vacuum natuarally.
Degree wheels set on zero are rarely on true zero, skim the head, change the head gasket thickness and your degree wheels change position slightly, thats why people degree the cams in.
Even at its best, vacuum will be low with such massive duration cams.
Edited by GTRPSI
hi guys, thanks for the replies,
i gave all the specs of the engine to sure cams and the purpose of the car. (80% strip and 20% street). so he went off that bassis. he has done a set of cams like this before, and to his knowledge, there have been no problems. the head has also had solid rb26 tomei lifters installed too.
i have base timing of 15 deg. is it worth trying a little more?
as for dialing in the cams with degree wheel, i will have to ask my engine builder about that. i have used him for years and so have my mates, but some times shit happens i suppose. he also tunes it.
the ecu is haltech e11v2 milspec.
i've been told to expect hp figures around the 750 to 840 atw.
it has a 18psi stall converter and 1300hp powerglide behind it from MV automatics ins SA. used to have built jatco 3 spd from keas, but smashed that to bits with the old setup. that was making around 720hp flywheel
  • Like 1
i would be checking for leaks again. but use an air compressor this time. i was chasing issues and found 2 leaks after pushing over 10psi pressure into the engine. works a treat.
thats a good idea, will try it tomorrow, i'll let you know how it goes either way
ok, smoked tested again and found 2 leaks. had to block the exhaust off to find them though, and still wait about 5 minf for that to fill up. the leaks were at the adjsutment screw on the fuel reg, and at the fitting going into the plenum for the brake booster. now has about 5 inhg at idle, idle around 1800-1900 atm, will do some tuning next week or so. need looser converter though. will post figures pics after tuning.
thanks for all the help guys.
We spoke to Camtech about our 26/30 also with a 80% strip/20% street setup and were recommended 280 duration 11.5mm lift cams for a easy walk in the park 600Kw at all 4 with a precision 7175.
RB30's also tend to absorb lumpy cams a lot better....
Will be interesting to see how user friendly you will find it on the street, post back with how it is to drive after you have tuned it.
Refer to my avatar.
I don't know what angle the tuner/engine builder are coming from with this combination of parts but hope it works out well for you - do the same as everyone else and you get the same results, sometimes its for the better... good luck with the rest of this, update when you've got the bugs ironed out as I am sure a number of us would be very interested to see how this come out :)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
