Sorry if this is in the wrong spot,but I am trying to fit a aftermarket taco,and can find a the single wire for the RPM, I can get the guage to light up and stuff but just no single, I have tried the wires front the ECU and on the back of the cluster, any ideas?
https://www.sau.com.au/forums/topic/437789-help-fitting-taco/
What brand of taco? old el paso?
Can't help, either hard or soft taco.
If you need to fit a tacho however...
You will need to find the correct wire from the ecu, or wiring diagram, and check with an automotive multimeter as they can measure rpm.
Hopefully the tacho is actually fine.
  • Like 2
  • 3 weeks later...
Has any 1 fitted a Tachometer to a 93 r33 gts s1 Nissan Skyline non turbo 2door Coupe, oh and it's silver and which 1 is the signal wire?
The Tacho's were an option on Silver skylines, had to pay an extra 99c for it to be enabled.
I feel like Taco's now
  • 4 weeks later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
