And what would you expect the plugs to look like on ethanol anyway? The shit would evaporate before you got the plug out. It's hard enough to read plugs on petrol since all the lead was removed.
Plugs looked fine, and were not causing misfire. No melting, or signs of DET damage.
The DET was picked up with a knockbox setup that Trent has been proficient with for 5+ years, I am sure he has heard more knock than any of us... Amplified 100 times over. :P
Very hard to prove without climbing into the cylinder at full noise. Considering the engine is brand new, I doubt there is any carbon buildup causing pre ignition, sharp edges in the quench perhaps, but I don't think Tony wants to rip the head off unless all other avenues are exhausted. (Plus we need to give the engine builder the benefit of the doubt, I am sure he knows what he is doing.)
What other causes of pre-ignition can be ruled out with the head on? Remember, this is happening on ethanol and 98...
More often then not its something stupidly simple....
How about the water temp sensor? Could that play a role in perhaps a timing correction table based on what temps or something??
highly doubt that is, Trent will know straight away.. you will see it in Nistune if the temp correction table is used as it lights up green.
I would recommend plugging up an EGT into each runner (one at a time I guess to keep cost down) and data log the EGT per cylinder for the same run/conditions 6x times - this would still be cheaper than pulling a head off
what about the effect of having a polished ported intake side, apparently this can be a bad thing and cause knock?
"The carburetor or the fuel injectors spray fuel droplets into the air in the manifold. Due to electrostatic forces some of the fuel will form into pools along the walls of the manifold, or may converge into larger droplets in the air. Both actions are undesirable because they create inconsistencies in the air-fuel ratio. Turbulence in the intake causes forces of uneven proportions in varying vectors to be applied to the fuel, aiding in atomization. Better atomization allows for a more complete burn of all the fuel and helps reduce engine knock by enlarging the flame front. To achieve this turbulence it is a common practice to leave the surfaces of the intake and intake ports in the cylinder head rough and unpolished."
picture of the droplets in my manifold i saw when removed
Edited by AngryRB
I would start back at basics.
Throw in another set of injectors or get the old ones flow tested, one lazy one and its DET city.
Make sure none of the injector wiring is a issue, right back to the ECU plug, one injector not opening enough or long enough will lean out the engine on one cylinder, enough to cause det so check wiring and plugs.
Run a test with 1 or 2 heat ranges cooler spark plugs, see what it does after the injectors have been tested, dont just test with another set of plugs of the same heat range, issue could be cylinder temps, im guessing there is no EGT probe.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
