Hey guy's
As the topic states im after a list of parts needed to convert to E85 e.g lengh of hose's, sizes of hoses, fittings, filter ect
Needs to support around 500kw + for my GTR currently setup up with a 3l serge tank and 2x bosch 044.. am i going to need another one also
https://www.sau.com.au/forums/topic/441156-parts-needed-to-convert-to-e85/
Ibe got a almost new bosch 044 ill sell you cheap if you need an extra one. I installed it just to rip it out a few days layer in favour of a walbro 460.
no worries thanks mate i will keep it in mind.. ill find out in a couple of weeks if i need 3 or not
So whats being said here is that for 500Kw + at the wheels that the standard fuel lines are large enough for the flow needed on E85?
If so whats the limit of the standard fuel lines?
Bosch 044's are E85 safe?
Edited by GTRPSI
Can always use the standard return as a feed and run an extra return line.
044's are rated at 500 working hours on E85.... Or so they say in the box. That's a bloody long time if it's a weekend car.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
