Hey guy's
As the topic states im after a list of parts needed to convert to E85 e.g lengh of hose's, sizes of hoses, fittings, filter ect
Needs to support around 500kw + for my GTR currently setup up with a 3l serge tank and 2x bosch 044.. am i going to need another one also
https://www.sau.com.au/forums/topic/441156-parts-needed-to-convert-to-e85/
Ibe got a almost new bosch 044 ill sell you cheap if you need an extra one. I installed it just to rip it out a few days layer in favour of a walbro 460.
no worries thanks mate i will keep it in mind.. ill find out in a couple of weeks if i need 3 or not
So whats being said here is that for 500Kw + at the wheels that the standard fuel lines are large enough for the flow needed on E85?
If so whats the limit of the standard fuel lines?
Bosch 044's are E85 safe?
Edited by GTRPSI
Can always use the standard return as a feed and run an extra return line.
044's are rated at 500 working hours on E85.... Or so they say in the box. That's a bloody long time if it's a weekend car.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
