also guys i need som e10-15mm 59.1mm hub centric spacers, i prefer non bolt on because i already have extended studs.
must have a 59.1mm hub.
any ideas?!?!
I've only used full lock in a car park.
Once lol. But yea like I said they going on my bimmer rims that are just for the drags. So yea.
Fed 595s for the pulsar daily rims. Leroy you find any caps mate!?
there's a cap at scottys house man...i saw it there other day
you only need decent lock for roundabouts, u-turns, hook turns etc :rolleyes:
anyway, we'll see how you go
even without full lock it will have a tighter turning circle than lets say a cressida...if i can park my cressida he can park a micra.. ;)
so just scored one of these.
look like shit and cheap and nasty hey.
nope. jdm so all the fanbois love em. usually around 150-250.
got on efor 90. which is good cos im freakin skint.
and hopefully picking this up on sunday.
again go from anything between 150250. im paying 150.
i will need to wind the km forward to match mine. anyone know how?!?!?
i currently have 309000 and im proud of that. lol
I'm sure you can find some dodgy Victorian to assist you with that
Theres a cluster guy in ringwood, probably do it.
Everything about this car is dodgy :P all our cars are
i wanna do it my self lol.
come at me youtube vids.,
and yea your right leeroy.!
hahahahaha. yea. i didnt want to do it that way tho.
It's easy as this.
Even Danny DeVito can do it - http://youtu.be/6IYOvUs-ul4?t=1m
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
