Not true, there are Holsets which perform very well on performance petrol motors- you have to get the right combos but there are varieties of HX35 which have been used very successfully on RB25s- I very nearly bought one instead of the GT3076R, only reason I didn't was I at the time figured I didn't want an external wastegate/aftermarket manifold setup.
I got HX35 laying around for preferably some one had a 3076 or similar to try it. It was a repair job for a school bus and the customer didn't came back.
They can make the power, how ever there are many options out today which are capable of the same amount of HP with better response and drive ability.
The same can be said for a LOT of popular turbos - everything can't be the best, so everything else has something better than it. The Holsets aren't the best out there, but they are far from the worst, and pretty far up there in terms of value for money.... the trick is just doing the research and identifying which ones are the ones which would work for you.
any opinions on master power turbos?
They seem solid and reliable, I am still waiting for more real world feedback on them before I form an opinion on their power versus response but one of my mates just got his R33 GTS25t tuned with a billet MP595 and made 330kw @ hubs on 19psi with a respectable power delivery, from what he's said.... will have to try and find out more about how it drives etc. It sounds awesome! :D
  • Like 1
i was but i still have the problem of my stock dump...after talking to a few people and umming and aahhhing a lot...i want to use a much easier dump configuration with vband's used for the wastegate..this will allow me to re-make the front pipe and dump to accomodate a couple of things that i also want namely a 3" flexi and a wideband bung....also make it easier to take apart in the future when i 30det it.
I had a hx 35 with internal gate and all it did was over boost. After I changed actuators like 3 times and all different types. I gave e up. I then just tied the gate open and still I was over boosting to about 25 psi. A matter of fact I new from experience I was maxing out the ecu on my rb20det. So i spent 800 dollars on a ROM tune ecu injectors and Z32 AFM. It started to eat the boost up. But after a while I was wondering why it's over boosting even with the gate open and tied open. So off came the turbo. I new it wasn't boost controller or waste gate.
I noticed that the gate flap wasn't opening all the way. I then found online that people were have the same issue. (Internal gate here) it was limited by the cover 5 bolts cover or somthing like that. The flap couldn't open all the way. Next at closer inspection I noticed that it was a internal waste gate but twin scroll t3 turbo. So in short only one scroll would vent and the other would keep on boosting. This has nothing do with it being good or not. But it bugged me for so long that I spent 800 dollars on ecu and injectors along with AFM. Plus down time waiting. I had better results with cheap ass ebay turbos. I just should have done that and change to external waist gate. Besides all the the turbo hit hard when it came in but was way to laggy for me.
Wasn't really blaming the turbo here. Other than the lag it has on a rb25. Keeping in mind that the flap still didn't control boost well. I do believe it came from a diesel truck that only boost form 22/30 psi. Hence it venting from one scroll. I got it free and wasn't complaining.
I know what you mean mate. I just was list my experience with it. But it was free. Totally. Just was a interesting boost issue I had. I personally don't like them. For the money I would pay for one I can get other turbos that just boost faster with less lag. That's me and I do understand that not all people are the same. It would be a boring world if it was like that.
I have been through my share of turbos and aftermarket parts on both cars. So I am hardly having a go at anyone for doing the same as I have done.
Usually the best results came from carefully thinking out what I wanted and paying the right price for the item. Nearly every shortcut I took ended up taking longer to sort out the issues created.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
