Ok, I've been on here long enough & gotten into enough trouble in my R32 GTS-T over a number of years that I think it's time i did a thread on it.
I'm doing my best to go back over all the pics I've saved since December 2007 when I bought it.
It came into my ownership as a clean & tidy 1992 model, paint code AH3 (wine red). A lot of people don't like the colour, but it definitely grows on you over time. I've loved it since day 1.
Specs when I picked it up:
* RB20 DET (130,000kms on dash) - original dash & mileage as far as I could tell, overall interior & exterior condition seemed to match the odo reading, so I purchased it in preference to some other 50K & 60K cars which looked like rat sh*#.
* 5 speed manual
* 17" lenzo wheels
* Microtech LT8 ECU
* Turbosmart dual stage boost controller
* 3" exhaust
* slotted front rotors
* HKS turbo timer
* Blitz BOV (stupid loud)
* Blitz FMIC
* front strut brace
* clear side indicators (VT commodore items)
* "high speed" NISMO badge on the boot
It looked very clean & tidy, had plenty of power for an RB20 & was a nice daily driver. Although initially with the Microtech the fuel economy was sh*# & high boost had been set WAY too high for a stock turbo with no supporting mods.
Early changes & modifications consisted of:
* HICAS lock bar
* removed Microtech piggyback ECU (then discovered it had been masking a faulty AFM, so back to the shop to be fixed & checked over)
* reset boost to 11psi low & 13psi high
* Walbro 255lph fuel pump added when stock pump was tired
* the obligatory pod filter & turbosmart BOV (later got me defected lol)
* several different sets of wheels, 17" & 18" as I found different models I liked & could fit
Removing the piggyback ECU & getting things set properly dropped my weekly fuel bill from $120+ to less than $70 for the same trip, & gained roughly 20kw at the wheels in the process. I can't remember the power figures at the time, but mostly stock with slight boost increase, so not earth shattering figures but good economy & reliability for daily use.
Following this there was mainly wear & tear items which needed attention:
* AFM as mentioned above (a pink label RB25 unit was retrofitted by Unique Auto Sports in 7 hills)
* diff rebuilt after it got real clunky
* new sports clutch when the stock unit was rather worn
* misc coolant & power steering hoses due to age
* coil packs upgraded to splitfire units when the stockers began to give me issues
* fitted GTR front seats
I went through phases of fitting gauges everywhere I could find room, but ultimately the running gear remained the same.
Then 1 day the boys in blue caught up to me while out cruising on a Thursday night. They didn't like the big white wheels (among other things), & at the peak of the strike force taipan era in NSW, an undercover unit defected me. I saw him coming but couldn't even make it to a mates place nearby to escape....you live & learn. Got done for the following:
* camber wear on tyres
* BOV not fully plumbed back
* boost controller
* exhaust too loud
* 1 more thing I can't even remember
Cleaned everything up & got all that sorted & cleared within a week or 2. They didn't even worry about the catch can or anything.
Along with the defect was a summons for EPA testing, so the car went in to be tuned on E85 to clear emissions. As the fuel system was stock, the turbo was disconnected & an adjustable fuel pressure regulator fitted to allow it to (sort of) run long enough to clear the test. Defects were cleared so I called to make an appointment to get the car checked....
There was no record on the system, so after all that I'd wasted money preparing for nothing....not happy, but at least it was all sorted & roadworthy again. Back to the tuning shop to get converted back to 98 & have the hairdryer reconnected.
The next several years up until December 2013 saw many kms with minimal issue. 1 more (heavy duty) clutch has been installed anticipating an engine upgrade, but otherwise mostly cosmetic mods were added & that's about it:
* 17" R34 GTT wheels
* GTR bonnet & grille (grille yet to be painted because I've been lazy)
* R33 GTS-T front brake upgrade
* later reupgraded to R32 GTR front brakes with slotted rotors
* Adjustable coil overs fitted
* DVD player & 7" screen
* GTR dials & display adapted to original GTS-T dash
* A larger UAS alloy radiator was added somewhere during this time period also.
December 2013:
The car now shows roughly 220,000 kms still on the same odometer it had when I bought it. The stock RB20 has survived 90,000kms of my driving, plenty of daily use, long distance trips, a bit of spirited mountain driving, the R34 GTR 10th anniversary cruise to Mt Wilson with the SAU club, etc. Only minor issues throughout this entire time.
New years eve 2013 the car came off the road to receive a new motor & gearbox combo. (RB20 is still running, may have dropped compression a bit due to age but haven't checked. The stock turbo is still in place with minimal shaft play also).
The new combo consists of an RB26 (N1 turbos) from an R32, an RB25 gearbox from an R33, & a single piece driveshaft made up to suit the combo. Engine (& many other parts including coil overs) generously supplied by our very own SAU member & wrecker, FATZ.
The conversion commences:
After 6 months of weekend work, the swap out is more or less complete & the car is now running:
Then the day it roared to life for the very 1st time:
Funny enough no major issues. 1 shot shows where I missed an oil block off & dropped engine oil everywhere, otherwise it fired up nicely on stock ECU with the N1 turbos & RB25 gearbox & everything else in place.
Now I'm in the process of reassembling the front end, finishing off things like bleeding the clutch, changing the throttle cable, etc to get it mobile once more. The car still has rego, & once I've had it running for a while with some future upgrades added, it will be getting engineered to remain registered without defects.
Future upgrade plans are a Haltech ECU with flex tune, bigger injectors to suit & some semi slicks for the track.
There's probably several things I've forgotten about over the years, but I will add anything else I recall as they pop into my head.
The plan was always to have a quick street car that can cope with weekend track use, & even be a daily if I need it to on occasion. I prefer something a little underrated that doesn't look seriously quick like a GTR. That's why I've kept the stock GTS-T wing & front bar, but added the GTR bonnet for a slightly different look. It will be staying as a RWD also. Once the car is running, there is a set of 18" rims with wider rears to aim for more traction. The 17"s pictured will likely be getting semi slicks for track use, then I will alternate between the 2 sets as required.
Very soon I'll be able to see if I've achieved what I set out to do when I bought the car.
If anyone has any questions about the ins & outs of this conversion, definitely send them across & I'll answer as best as I can.
Cheers for reading.
https://www.sau.com.au/forums/topic/446244-cmoneys-r32-gts-t/
cheers guys, there has been much research done before attempting this swap & it looks like it's paid off.
I was waiting for some nasty electrical gremlin or something, but even wiring in the resistor pack & changing ecu wasn't stupidly hard.
now once it's mobile I will compression test it & make sure all is well before going to get some base power figures before mods commence....
Edited by cmoney
ok bit more progress today, gearbox now has oil & the wheels turn lol.
i main issue ive discovered though, i have no boost....nothing what so ever.
so whilst fixing some stuff underneath, i removed the y-pipe & ran it for a minute. gave the motor a couple of revs & i can hear the turbos spinning & sounding relatively normal. but theres no boost at all on the gauge. when you rev it, the vacuum disappears & i get up to 0 psi, but it wont build any higher.
as the car is up in the air, i tried it in all gears with the wheels spinning to replicate driving on the road (with exhaust back together), still nothing. switched the boost controller vacuum hoses in case i got it backwards, still the same. engine starts, idles & revs without issue, hot or cold start no problem, just no boost at all. well engine sounds like it has a bit of a miss or just isnt running clean once you start to rev it, but im guessing thats because its waiting for some sort of boosted air.
anyone else had a similar issue?? im hoping ive just got some 1 way vacuum hoses around the wrong way or something stupid....
cheers
If the wheels are not on the ground then the car will not make boost. It needs load (the action of trying to move 1500kg of metal) to make boost. That's why it's hard to make full boost before redline in first and boost builds quickly in third/fourth.
Drop it off jacks and as soon as you drive it around, your boost will magically reappear!
Yeah mate, I can understand being confused about it if you didn't know that little bit of info :)
When you have the car back on the ground and ebbing, stick it in neutral and rev it, will hardly build any boost same as on the jackstands.
yeah I know about the safety in the factory ecu so it doesn't build boost in neutral, that's why I tried it in gear. I just didn't think being in the air or on the ground would make a difference if it was in gear
ok got it back on the deck & driving under its own power.
my current throttle cable is way too loose for some reason, so i can only get maybe 30% use out of it. that said, i managed to spin it up on the grass & hit a MASSIVE 2psi lol. at least it is kind of boosting.
its running rough with a misfire, now i think i need to pull the intake manifold off & replace all the gaskets....fun fun fun.
at least the rb25 box conversion & speedo is all working.
Edited by cmoney
Should be called Cmoneys Money pit hahaha. Good thread mate. Been waiting for you to finally finnish it since i finnished my 32 lol. Now reading this you make me want to rip the 20 out the race car and put a 26 in it :P I still shotgun second drive. and passenger on its first track day.
Need any help removing manifold let me know ill come say hi :)
so instead of having my car ready & being able to enjoy it on the r32 GTR 25th anniversary cruise, instead it looks like i broke my rb26 just a few weeks after i got it running.
ah well, time for a decent build from scratch now....
specs, power output & hopefully quarter mile times will be posted in several months once it has been built, tuned & tested.
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
