Took the car for another drive today to rack up a few more Km's with the SAU crew, went up the Bells Line of Rd and down to Megalong Valley the car is feeling great!!!
cant wait for pic's to be posted either!!! and I'll update.
so all is good for the trackday tomorrow at SMSP South Circuit!!!
  • Like 2
well I've got a few things to do after its shake down at SMSP.
need to find this damn oil leak wasn't the sump, doesn't appear to be the turbo oil drain on the block so it's got to be a bit higher.
also need to re-bleed the brakes the pedal dropped a fraction.
on the drive home could hear a bit of a rattle in the arse end sounds like something needs tightening.
need to find out why the speedo stopped working after the g'box reinstall
also I had a bit of tyre rubbing but it wasn't on the outer lips of the rear guards so have to check that out too
and whilst I'm dropping the oil as I'm sure its cactus even though it still looks clean and smells alright, im going to setup my twin oil coolers that I never had time to fit.
hopefully I can make a setup looking something like this....... also going to remove the aircon condenser etc and see if it's worth making some better ducting for the air box.
and another thing to do is enclose the surge tank I'm thinking more of a Perspex shield from the back of where the back seat used to be to the roof so it's still easy excess if there's a problem just by opening the rear hatch/boot.
  • 3 months later...
Well its been a long time since I done any updates but she's up and running again but still chasing down a oil leak I'm hoping its not a faulty second hand turbo!!!
I've fitted and plumbed up the oil coolers and duct's
removed the air con pump and fitted a smaller belt.
had to fit new headlights to clear the oil coolers,
relocated the battery to the passengers side back seat.
and fitted a bunch of gauges as well!!! Didn't like the look of the RE Amemiya carbon gauge cluster so I painted it in a plastic textured paint instead.
also replaced the turbo with a second hand one and fitted my 3" dump pipe.
with the oil coolers in place the pop ups don't fit anymore :( as you can see in the 2nd & 4th photo that the oil lines only just clear the headlights I've put in.
I don't really like the look of them either but they suit the need and once rego runs out I will be using them as the air ducts for the air box.
this car used to be white but it had a respray back in Japan, another reason why I was able to get it cheaper :) don't mind the yellow now but it wouldn't have been my first choice either. the yellow is actually a rare colour though!
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
