Hey there, build looks like its coming along great! I have a quick question. Stock belt for the alternator is Gates K040347, which is about 1/2" or 16mm longer than the K040340 belt that you used. Is that because the Fluidampr has a smaller size? I have a fluidampr that I'm going to be installing soon, so looking to see if ordering the stock belt size would not be right. I'm looking at the Gates blue racing belts too:
Gates K040347RB Blue Racing Micro-V Belt - http://www.amazon.com/dp/B000TTKPF2/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=19NGU4K5QEJSZ&coliid=I3BFQIAYWSJ065 Gates K040340RB Blue Racing Micro-V Belt - http://www.amazon.com/Gates-K040340RB-Blue-Racing-Micro-V/dp/B000TTKPDY/ref=sr_1_1?s=automotive&ie=UTF8&qid=1462200886&sr=1-1&keywords=K040340RB
Honestly I never measured and compared to the factory harmonic balancer (I guess I could because I still have it), But here is a picture I snapped of the belt identification and you can see that it adjusted pretty much in the middle of the alternator adjustment, so it's definitely close and gives room to adjust for any stretch. I am willing to bet 1/2" wouldn't hurt anything though because it's pretty adjustable there. The PS belt had much less room for error for my setup. (78 was too long and 65 was too short).
Ok cool man. Thank you for the info. I'll just get the K040347 and the same belt you got for the PS. Keep up the good work!
Drat!
One big thing. Oil pan has about 6 pin holes in the welds. Slow drips of oil out of them. This will surely get worse when it heats up. This is a pretty major issue as of now but...
Haltech setup and wiring went very well. Went through menus and setup everything and I'm having an issue with my crank / cam pickups.
I am getting voltage changes at my GAPS in the harmonic balancer when rotating by hand, and I get voltage changes in my TOOTH in my cam trigger as well when rotating by hand, but the count is wrong in my computer and it won't give an rpm signal.
After reading about the honeywell GT101 sensor it will read GAPS And TEETH but they are reversed on the low / high voltages. What I mean is that I think the haltech is expecting a short-timed LOW voltage on the crankshaft and I'm not giving it that. It is likely staying LOW so long that it times out? I have an open query to Haltech about it.
I'd like to at least hear it run before getting to that oil pan! AND this thing took 9 quarts of oil from dry! 9!!! crazy.
Haltech is saying that their software doesn't care about highs or lows (teeth or gaps) just changes in voltage so it's likely getting noise somewhere else. I'm going to check my cam bolts depth by greatly exaggerating the longer bolt from the shorter 3 tomorrow.
Halfway embarrassed to say but I tried an industrial metal epoxy on the oil pan. First drained all oil. Then pumped thinner into the sump through one of my oil drain fittings (so as to not wash the whole engine with it - only the sump area where the welds are) and watched it rain thinner out of the holes. Then drained that, took heat gun and sweated out remaining thinner / oil. Final rinse and reheat then applied epoxy to the all of the welded areas. I hope it holds if not I only lost a couple of hours (compared to pulling engine or pan this is nothing really).
Prayers welcome :)
  • Like 1
It was the tiniest of pin holes. Had 5 of them. Welder said he did the water test and checked it but there's no way I believe that. I could have spot fixed it, but I figured they may not all be visible at room temp so I went on with coating the whole weld.
I used belzona 1111 metal epoxy. It is rated for temp and made for metal repairs. I just need it to stay sealed.
And I am not planning on this being permanent, I just need to get the car tuned and tested on. Of course I will fix it correctly later but I'll see if I have any other issues first.
OK so the epoxy worked pretty well. There is still one that I simply just missed covering up, but I think I can fix it later when I permanently fix the pan.
BUT the car runs!!!!
VERY IMPORTANT:
When using GT101 (or any other cam and crank triggers) the signals are backwards in the Haltech for the AEM "24 and 1" setting that is the other default choice in the Haltech Platinum pro plug n play. The GREEN/YELLOW signal wire is for the CAMSHAFT HOME signal (1 click per camshaft rotation).
The other wire works for the crankshaft on a 12 groove crankshaft.
  • Like 4
Well I had an issue. A major major issue.
After getting everything up to temp and going well on coolant and oil pressure I started on the throttle body and cracking it for more airflow as well as setting TPS. I got the car idling and then started setting base trims and revving the car a bit (didn't want to just idle a new motor) so I started revving a bit up to 5-6k...light revving only no loads. Well it was sounding good and trims coming in great and then I heard a noise. First was a bit of a "clunk" noise that both my helper and I heard (backfire in intake of sorts) then I heard the knock. Rod knock...shut down, checked oil again - level is good (halfway up dipstick so some air came out). Cranked back up breifly and really decided not to give any more rpms and shut it down.
This bothered me to no end all night. I can't sleep and it's really getting at me because this is the first bottom end I have ever put together (measuring all myself etc) that has ever given me such an issue.
So I am writing now to say that I completely overlooked filling my oil cooler and my oil cooler feed lines. We primed FOREVER without the plugs in to get pressure but I didn't even think about the greddy thermostat. What the hell total oversight. I'd bet the farm that while we were doing our little revs the oil temp finally got to temp and opened up and sent a half quart of air to my bearings. I'm really scared the clunk was the camshaft starting to seize.
I have no clue why I didn't think to pump through the cooler with a fluid pump to prime it but I didn't...
Since I need to pull the oil pan anyway to fix the last leak I'll start there and check no 1 rod.
It should be noted that the oil pressure was stupid good. Like incredibly high. On the stock gauge at idle just under the '4' at idle! Also backed up by haltech pressure gauge. But pressure is only part of the indicator...as this is close to the housing after the pump...and this would have pushed the air in the cooler straight to the bearings in the event of oil thermostat opening.
I attached my oil filter insides. What do you guys think?
  • Like 1
Can you post a pic of your thermostat mate?
​I'm pretty sure the Greddy oil thermostats are never fully closed, to avoid the engine getting a dose of cold oil once it gets to temp. So I doubt very much your engine got any air due to it opening.
Also, how much of that metal would you guess came from you cutting the filter open?
Edited by barbados_26
  • Like 1
The metal in the pleats (valleys in the picture) are definitely from the inside of the engine...not from cutting. Oil was clear but lots of shimmery metal. Could be normal for break in honestly.
The picture in the bath is hot (oil cooler receiving oil). Picture out is cold. Entry would be on table side coming through the port with the hole that gets covered when heated (which forces through the cooler).
Oil pressure was strong. Never noticed an issue even during knocking sounds.
Shit ay, that sucks.
​I haven't run in a new engine before, so unfortunately I can't help you there. Hopefully some of the more experienced blokes will be able to give advice.
​Either way, I hope it's nothing too serious
I'd almost guarantee that it's done a bearing or worse. Normal break in doesn't get glitter oil :(
I installed an oil kit with thermo on my engine and never even thought to prime it, but didn't get any issues, maybe its something else?
I mean, even if it wasn't all out by the cranking you did, the amount of oil being pumped through the partial opening, (assuming it was there?) when the engine was idling and still not up to temp would easily have pushed it all out. The pumps move a crapload of oil remember!
We cranked forever. Even broke fittings at turbo to make sure it was clean oil and flushed before sending any break in lube there.
This video is just minutes before the noise.
https://youtu.be/2zFD_4tLqQA
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
