Hi, having recently purchased a completely stock R34 im looking into doing some handling upgrades, nothing crazy just general street use and a trip to the track twice a year. However that being said I don't want some sloppy or something that's going to make it damn near uncomfortable. Ive looked at getting coil-overs with lower spring rates but is that really the best option. Due to the fact that I like taking corners pretty fast it would seem like a good option, but could I achieve similar performance with lowered performance spring and shocks and upgraded front and rear strut braces and a sway bar down low? The car will only be making around the low 300hp at the wheels and its got decent grip and fairly wide tires. In short could a more street-able option be to ugrades springs and shocks and put in braces all round then go for coil-overs, but still be able to level with coil-over performance in general street track use.
Thanks all :)
https://www.sau.com.au/forums/topic/448058-r34-handling-upgrades/
Hey Chids34 - I also recently got my hands on a stock 34, I have been hunting around now for some decent suspension for 2 reasons - 1.) I hate how high it is, and 2.) I would like some better performance.
Basically I walked into petters and got a quote of $1400 for their fully adjustable fully warranted suspension setup, or $2300 installed plus a 1500km set-up time where in that 1500km you could bring the car back anytime and have them alter the ride stiffer/softer, lower/higher etc. Also everything they do is warranted for 3 years.
I've heard from GTR owners that BC coil overs are a fantastic option as they don't apparently sacrifice any comfortability for street use and they are around $1100 on ebay.
I've also seen nolathane bush kits for the 33's and 34's on ebay from $80-$300, depending on how much you want to replace.
Let us know if you decided on something and how it feels/handles on the road, also would be keen to see ride height.
The guys that think those BC's have any value in them whatso ever have rocks in their head. May aswell put some railway sleepers in. Might do a better job.
- Set of mid-range coilovers, such as MCA, Shockworks (I have these in 8/6) or get onto sydney kid for a bilstein setup.
- Sway bars front and rear
- Rear camber and front castor arms
- Adjustable front camber bushes
- Hicas lock bar
- Replace every other bush you can afford
Alignment, then sorted.
Edited by owen1r
- Hicas lock bar
The above is the gospel according to us.
Thanks for the info, but to answer my actual question can I achieve the same results without coilovers? Going the coilover way is great and all but I was asking if similar results can be achieved without them, not whether or not I should use them because everyone else does, which yes would suggest they have there advantages but I'd like to know anyway.
Thanks J
Everything is a coilover. The standard suspension is technically a coilover design. What I think you mean is an adjustable coilover kit. The suspension needs to match the rest of the cars mods and its usage. Given you said you only wanted 220rwkw you may be able to get away with a cheap coilover set and still get what you want.
I personally take the 'do it once, do it properly' approach. Future you will probably thank you ;)
Everyone's a critic, until they actually use them, then their input is worth listening to. ;)
If you can't set up adjustable suspension you are better off with the Bilsteins.
  • Like 1
To the OP - if you're going to take the "do it once, do it right" approach then I suggest heading to pedders and just have a suss out of their stuff, but it is pricey. Otherwise theres not much info on the type of suspension people are running and feedback, perhaps a new thread should be started so people can tell us what gear they're running and what its like on the street/track, how easy it is to adjust, what settings they use how much they paid etc etc. Would be a handy thread!
Edited by vetter2769
I think people understand what I mean when I say, 'coilover' it clearly doesnt mean im putting the stock 'coilovers' back in, it more or less implies upgrading to a 'coilover' those that are bought aftermarket. And yes thankyou there is a difference I can get lowered springs and standard shocks, is it a coilover? technically if I sold it to someone would I call it a coilover? probs not. And to be honest your not even answering the question your just being obtuse, is the question should I put coilovers in? no its not.
Thanks for your feedback.
I've been in a few cars with them. They're terrible. Isn't that enough?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
