  • Replies 50
I don't see the small block chevy as such a bad thing.
They still use it in the Corvette so what's the big deal?
Should be a nice ride but I'd be thinking alloy head or even block.
T.
Do you recall the HPI article that had a Corvette chop an R33 GTR in a straight line, and also the HSV GTS with exhaust, cam and remap that went even stevens when both jumped on the loud pedal with an R34 GTR running exhaust / filter/ Power Fc and boost...
Chevs are alright in my book, the problem is finding a decent chasis to put one in :(
I think there is a few people in here with a fear of torque....
Not really.. I tend to think that the RB2x is an integral part of what makes a Skyline a Skyline, in the same way that an RX7 would not be the same without its rotary engine. The engine is (an important) factor in defining the cars character.
Hence sticking a thumping V8 fills me with mixed emotions. Good for him for doing something different, but IMHO its the same as dropping a V8 into anything and not really a "skyline" anymore.
LW.
Also, it's not like our RBs are torqueless - so everyone thinking "just imagine the torque" might want to rethink that. Turbos are one of the best ways you can add torque. Just look at the latest WRX STi - 394Nm from a 2L!
That aside, I do like the idea of a V8 in a Skyline though. It's something different. That engine would just be near the bottom of my list. VH/VK series or a 3UZ would be the way I'd go. Good work though, anyway.
I think I remember reading that.. Basically the only thing giving the gtr the upper hand was the 4wd.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
